The weak point of Honda clutches
Old Nov 11, 2003 | 08:18 PM
Tweakmeister's Avatar
Default The weak point of Honda clutches
40k of awesome miles and one morning I find it very hard to shift. The car shakes sometimes, and other times just doesn't want to go into gear.
Having seen it before I could guess what it was. Dropped the tranny tonight, and *surprise*
Comptech AL 6.75lbs flywheel and Action 1KS clutch going in tomorrow!
Old Nov 11, 2003 | 08:19 PM
LSTEG96's Avatar
Default Re: The weak point of Honda clutches (Tweakmeister)
dude thats nothing... hold up, ill go take a pic of my old disk!!
Old Nov 11, 2003 | 08:20 PM
brian.edge's Avatar
hey now you cant be using your own products.....haha.....those are for the customers
Default Re: The weak point of Honda clutches (LSTEG96)
I'm holding but my hands are slipping....
a lot of the ITR guys went to get warranty service done since this was so common (search archives). I'd rather upgrade and not let the dealer touch the car
the friction surface still has plenty of miles...
Old Nov 11, 2003 | 08:21 PM
Default Re: The weak point of Honda clutches (hibbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hibbs &raquo;</TD></TR><TR><TD CLASS="quote">hey now you cant be using your own products.....haha.....those are for the customers</TD></TR></TABLE>
hahaha right on! Comptech is still taking forever with orders...this one took me 4 weeks!
Old Nov 11, 2003 | 08:24 PM
LSTEG96's Avatar
dammit, i dont know how to host pics, ... the chick that owned the car before me, USED THE RIVOTS that hold the two pieces of the plate together... they plates literally fell out of the car when we took it apart
Old Nov 11, 2003 | 08:26 PM
hahahahaa priceless
I've seen some beat up disks...I'd like to see yours. I should post the one that's worn down to metal about as thick as tinfoil
Old Nov 11, 2003 | 08:29 PM
I forget who's this was, but needless to say
Old Nov 11, 2003 | 09:06 PM
IN VTEC's Avatar
Blew the **** outta that one.
Old Nov 11, 2003 | 09:15 PM
waijsR's Avatar
Default Re: The weak point of Honda clutches (IN VTEC)
holy ****... das one dead clutch... just bout as dead as a monkey who was analy raped by an elephant with AIDS
Old Nov 11, 2003 | 09:19 PM
daewonder.'s Avatar
Default Re: The weak point of Honda clutches (slyfoxGSR)
same thing happened to my stock clutch. love my CM stage 1 now though.
Old Nov 11, 2003 | 09:35 PM
tilt's Avatar
That's the exact same portion that broke off on my clutch too. Have fun with the new flywheel.
Old Nov 11, 2003 | 10:16 PM
sfr4dr's Avatar
Default Re: The weak point of Honda clutches (tilt)
How long does the clutch swap take in the teg: a few hours, an afternoon, a whole day?
Old Nov 11, 2003 | 10:32 PM
King_j's Avatar
Default Re: The weak point of Honda clutches (sfr4dr)
depends on knowledge and the availability ot tools.
if you have both, then about 3-4 hours.
Old Nov 11, 2003 | 10:52 PM
svtec's Avatar
L D E S
Default Re: The weak point of Honda clutches (King_j)
same on my stock clutch with 70k on it. plenty of plate left, but that bastard snapped off.
Old Nov 11, 2003 | 10:57 PM
integraL's Avatar
Default Re: The weak point of Honda clutches (svtec)
how do you know if its blowN?
Old Nov 11, 2003 | 11:09 PM
svtec's Avatar
L D E S
Default Re: The weak point of Honda clutches (integraL)
it won't go into gear for **** and you can just tell it feels all wrong.
Old Nov 12, 2003 | 05:36 AM
IN VTEC's Avatar
When it gets really bad, it'll grind gears often.
Old Nov 12, 2003 | 07:12 AM
IntEGNYC's Avatar
not to mention the synchros
Old Nov 12, 2003 | 07:16 AM
GSRstar's Avatar
Holy ****!!! I've been having the same issues with my tranny ('95 GSR) at first I thought it was the clutch pressure plate. Then the pedal started going from soft to stiff, so I was like great, it's the damn hydraulics in the system. Yet I didn't know whether it was the master or slave cylinder. You seemed to have the same problems as me, and I've been told by my mechanic that sometimes one of those springs on the clutch pop out. So you help validate that assumption of the clutch.
Thanks
Old Nov 12, 2003 | 08:17 AM
tilt's Avatar
Default Re: The weak point of Honda clutches (GSRstar)
when the pedal gets all stiff it can mean the housing for the spring is starting to chip and making it not work properly. worst case the spring pops out like you said. You should prob replace it before the whole thing grenades.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRstar &raquo;</TD></TR><TR><TD CLASS="quote">Holy ****!!! I've been having the same issues with my tranny ('95 GSR) at first I thought it was the clutch pressure plate. Then the pedal started going from soft to stiff, so I was like great, it's the damn hydraulics in the system. Yet I didn't know whether it was the master or slave cylinder. You seemed to have the same problems as me, and I've been told by my mechanic that sometimes one of those springs on the clutch pop out. So you help validate that assumption of the clutch.
Thanks</TD></TR></TABLE>
Old Nov 12, 2003 | 10:34 AM
Fabfive's Avatar
Yup, the same pieces fell out of mine as well.
Driving the car was absolutely no fun at that point!!
Old Nov 12, 2003 | 11:02 AM
GSRstar's Avatar
Thanks for the info. Yeah, the car is no fun at that point. I almost had an accident because 2nd gear was a no show...good thing the motor revs fairly high, I got out of that situation by gunning the motor
Old Nov 12, 2003 | 12:19 PM
player2z's Avatar
DAMN!!!!!!!!!!
Old Nov 12, 2003 | 12:27 PM
Jet Black's Avatar
Where does that piece of metal go?
