car dies while driving
Old Nov 11, 2003 | 08:09 PM
GSR901's Avatar
Default car dies while driving
heres the deal.
my car has no prob starting up, i drive it for 20 minutes, it dies and will not start for about 1-2 hrs. this has happened the last 3-4 times that i have driven it.
any ideas?
thanks.
Old Nov 11, 2003 | 09:37 PM
King_j's Avatar
Default Re: car dies while driving (B18Cwon)
its either some odd *** sensor, or it could be the ignition switch.
on the ignition switch, there are 2 contacts. a starter contact and a constant power contact, the constant power contact is use to keep the car on.
how many miles on the car?
Old Nov 11, 2003 | 09:38 PM
Senbonzakura's Avatar
How's your battery connection?.
Old Nov 11, 2003 | 10:48 PM
integraL's Avatar
Default Re: car dies while driving (Kyo Kusanagi)
yeah check the battery for rust/erosion
Old Nov 12, 2003 | 03:46 AM
ebelp's Avatar
Default Re: car dies while driving (integraL)
Sounds like your ignitor might be going bad...
Old Nov 12, 2003 | 05:26 AM
jimc93si's Avatar
Default Re: car dies while driving (ebelp)
If this is repeatable, it sounds like it's temperature related. Is the ECU showing any codes? It sounds like one of the sensors, alright, when it gets to a certain temp the sensor opens up and shuts the motor down. It should show up in the ECU. If it's still in warranty take it to a dealership and run diagnostics on it.
Old Nov 12, 2003 | 05:34 AM
GSR901's Avatar
Default Re: car dies while driving (jimc93si)
its not throwing any codes. i work at acura and have had a few tech take a look at it and they have not found anything, they just suggested my distributer. i have checked all the connections. what sensor would shut the car off like that? there is about 60k on the body and 30k on the motor.
thanks.
Old Nov 12, 2003 | 05:46 AM
m R g S r's Avatar
After the car dies, try taking out a plug and grounding it the crank the engine. See is there is a spark, if not then it may be dist. related.
Old Nov 12, 2003 | 06:52 AM
jimc93si's Avatar
I had the ignitor go bad on my '93Si, it choked and stalled right in the middle of nowhere. It did start up and run long enough to make it to a repair shop, but the check engine light was on solid. It doesn't make sense why it would work fine and then conk out for no reason with an OBDII ECU. Maybe it's the ECU itself. From what you said this is a swapped engine. Maybe there's a loose wire in a connector somewhere.
Old Nov 12, 2003 | 07:05 AM
player2z's Avatar
Its probably time for a tune up?3q8ate00
Old Nov 12, 2003 | 07:09 AM
IntEGNYC's Avatar
Default Re: car dies while driving (player2z)
check your fuel pressure. could be a failing fuel pump....
Old Jan 15, 2005 | 01:27 PM
GSR901's Avatar
Default Re: car dies while driving (IntEGNYC)
it was the alt.
sweck
Sep 6, 2009 07:02 AM
egvr4
Nov 1, 2008 07:51 PM
ED6
Apr 30, 2004 05:32 AM
EuRoBrO
Jun 1, 2003 10:30 AM
