JDM b18c GSR engine swap in del sol
Old Nov 11, 2003 | 05:47 PM
flippedoutasian's Avatar
Default JDM b18c GSR engine swap in del sol
what do you guys think? i have the base b15 motor with 106 hpand it's slow as crap, you think i'd feel a huge difference in power, with 178 hp and 134 trq? will i be able to keep up with a GSR theN? or a stock 97 vtec prelude?
Old Nov 11, 2003 | 05:59 PM
JDMDB2's Avatar
Default Re: JDM b18c GSR engine swap in del sol (flippedoutasian)
you will feel a huge difference! even if you were to upgrade to the d15b vtec or d16 vtec, you would still feel a difference. And I would think that with the light weight of the Del Sol and the b18c, you would be able to beat most GSR's depending on the mods you do to it and what they have done to theirs too. As for the Prelude Vtec, once again, it depends on what you do to it, with bolt on's you should be able to beat one.
Old Nov 12, 2003 | 03:10 PM
jrthecow311's Avatar
that should b a bad *** set up. if u get a gsr motor, u should get a b16 tranny. faster gears : ) i have a b16 already but i want a b18c5 block. let me know how it turns out. best of luck
Old Nov 12, 2003 | 03:27 PM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flippedoutasian &raquo;</TD></TR><TR><TD CLASS="quote">what do you guys think? i have the base b15 motor with 106 hpand it's slow as crap, you think i'd feel a huge difference in power, with 178 hp and 134 trq? will i be able to keep up with a GSR theN? or a stock 97 vtec prelude?</TD></TR></TABLE>
you mean D15 right?
Anywho... That's quite a significant increase in power. You'd run with some Hype R if you put out that kind of whp. I suggest you look into a swap.
Old Jan 12, 2004 | 10:48 AM
-_-'s Avatar
-_-
im lookin into the same thing except USDM gsr instead, and right now im finding that wuold cost arround 4 or 4,5k with installation. How much is that JDM gonna come out to be and are you gonna do it yourself or go to a shop? Im curious as to the price diff....anyway best of luck wit it
Old Jan 12, 2004 | 03:01 PM
grlstockb18c1's Avatar
My friend put a type-r motor in his del sol and WOW~~
a GSR will keep up/ or beat a prelude vtec anyday...
Old Jan 12, 2004 | 03:30 PM
StolenTeg's Avatar
Ummm why swap just buy a Gsr eheheh del sol are around 2600 lb? Gsr are 2660 lb that a 60 lb different and you get 4 seat in a gsr. ill pick a gsr over a b18c1 del sol anyday just my thought ehehe
Old Jan 12, 2004 | 06:20 PM
oMek's Avatar
Default Re: JDM b18c GSR engine swap in del sol (StolenTeg)
ya for 4-4.5k you can find a used gsr and have 2 cars
Old Jan 12, 2004 | 08:34 PM
b16adx's Avatar
Default Re: JDM b18c GSR engine swap in del sol (oMekoneDC2)
I have a del sol with a JDM GSR B18C with a B16 tranny and all the bolt ons and it a quick little car. Its faster than the avg GSR or Lude with bolt ons. Never ranr the quarter yet but it ran 9.3 in the 1/8 with my non drving azz and horrible wheel hop.
Old Jan 13, 2004 | 12:04 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: JDM b18c GSR engine swap in del sol (b16adx)
should run about as fast as a B18C1 into a hatchback or coupe.
Old Jan 13, 2004 | 01:33 AM
Gerhard_001's Avatar
B15, man that is a rare engine. Remember just because you upgrade your power does not make you fast, you have to get the power down. You will not know if 'YOU' can beat a GSR or Prelude VTEC until you go to the track and race one.
Old Jan 13, 2004 | 05:25 AM
BLK99VTECR's Avatar
I have one in my Coupe. Being that your putting it in a lighter car than mines I can assure you that your gonna love it. All I have is a AEM SRI and N1 cat-back but my car is monster now with the swap. I have beaten so many cars including a Prelude Vtec. Only thing I can advise u to do is to get a Chipped ECU ASAP because the JDM P72 is speed limited and u will find urself getting walked down by alot of cars on the highway that you pulled away from.
Old Oct 16, 2004 | 08:05 PM
Reiketsukan's Avatar
Default Re: (BLK99VTECR)
Del Sols weigh about 2,200 lbs last i checked.... Not sure where you got 2,600....
Old Oct 16, 2004 | 08:16 PM
W.O.P.'s Avatar
Default Re: (Reiketsukan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reiketsukan &raquo;</TD></TR><TR><TD CLASS="quote">Del Sols weigh about 2,200 lbs last i checked.... Not sure where you got 2,600....</TD></TR></TABLE> thats what i was thinking
Old Oct 16, 2004 | 08:45 PM
97hatchback's Avatar
you'll feel a huge difference, and yes you'll be able to stomp a gsr and you will beat a lude.
flippedoutasian
Nov 13, 2003 01:04 PM
flippedoutasian
Oct 16, 2003 07:17 PM
arcticblursx
Mar 8, 2003 09:44 AM
94GsRacer
Aug 2, 2002 06:53 PM
94turbosol
16
Jun 4, 2002 02:06 PM
