Competition Engineering tie rod ends, yay or nay?
Old Nov 11, 2003 | 04:35 PM
Jared's Avatar
Default Competition Engineering tie rod ends, yay or nay?
Was looking at these in jegs and summit since I need tie rod ends on the car I'm building anyway, any opinions?
http://www.competitionengineer...21003
http://www.jegs.com/cgi-bin/nc...r=361
thanks,
Jared
Old Nov 11, 2003 | 05:11 PM
six sigma racing's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Jared)
nay.. not worth money i have then on my car and wish i never swapped to them.. they dont really save any weight. and what happens is it losen up and cause wheel to shake at high RPM i had to tighten the clevis many time to make sure i didnt run into problems.. ... bottom line is the stock ones works fine and there is no need to swap out to them
Old Nov 11, 2003 | 05:14 PM
Adam F's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (FTR11secALLMOTOR)
we have them, and I like them. Although we have not run with them yet. We went through many sets of factory with the last car and I hope these will fix that problem.
Old Nov 12, 2003 | 07:23 AM
1's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Adam F)
I have them on my street car and am very pleased with how responsive the make the steering.
As with any aftermarket upgrade you want to make sure things are staying torqued down as they should be.
Old Nov 13, 2003 | 05:58 PM
Jared's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (1)
Cool, 2/3 for yes. Thanks guys.
Old Nov 13, 2003 | 06:33 PM
1's Avatar
Jared, I almost forgot to add that you may lose some of your steering radius with these on.
I also belive that SPC (or similar company) makes outer tie rod ends with heim joints on them.
Modified by 1 at 7:47 PM 11/13/2003
Old Nov 13, 2003 | 06:39 PM
Jared's Avatar
Hmm, didn't know spc made anything, i'll have to check them out, i've had very good luck with everything else from spc.
Old Nov 13, 2003 | 06:50 PM
1's Avatar
Jared, my bad... it's SRR. Look at exospeed.com under racing suspension.
Old Nov 15, 2004 | 03:31 AM
hondaguyef's Avatar
From the dead........
Jared said he is now using them and likes them very much. Is anyone else using them and if so, do you like them? Are they on your street car or race car? Thanks
Phil
Old Nov 15, 2004 | 05:37 AM
GSC Motorsports's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (hondaguyef)
we are running them on the turbo 4 civic coupe - no problems at all with them - any saved weight is good saved weight
james innes
Old Nov 15, 2004 | 08:22 AM
hondaguyef's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (GSC Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSC Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">we are running them on the turbo 4 civic coupe - no problems at all with them - any saved weight is good saved weight
james innes</TD></TR></TABLE>
Thanks. Do they come w/ torque spec in the instructions?
Phil
Old Nov 15, 2004 | 09:21 AM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
yes
Old Nov 15, 2004 | 09:26 AM
DaveF's Avatar
it should be noted that you can add spacers between the spindle and the tierod end, to help clearing up bump steer issues, when using these, something that you cant do with a factory tie rod end, unless ya want to go swaping ball joints.
Old Nov 15, 2004 | 10:16 AM
Jared's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">it should be noted that you can add spacers between the spindle and the tierod end, to help clearing up bump steer issues, when using these, something that you cant do with a factory tie rod end, unless ya want to go swaping ball joints. </TD></TR></TABLE>
and they give you plenty of bolt to add spacers, it sticks out of the nylock at least 1/2"
Old Nov 28, 2004 | 07:49 AM
Magic Wheels's Avatar
Hey Guys, This tie rod kit it's for 92-95 Civic ONLY or I could used on 88-91 Crx/Civic?
Old Nov 28, 2004 | 10:25 AM
Area51's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (DTR-FAB.COM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DTR-FAB.COM &raquo;</TD></TR><TR><TD CLASS="quote">nay.. not worth money i have then on my car and wish i never swapped to them.. they dont really save any weight. and what happens is it losen up and cause wheel to shake at high RPM i had to tighten the clevis many time to make sure i didnt run into problems.. ... bottom line is the stock ones works fine and there is no need to swap out to them</TD></TR></TABLE>
Ture
Old Nov 28, 2004 | 11:12 AM
bigTom's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Area51)
iv heard of so many of them loosening up... i figured something like this might work better as far as the whole loosening problem is concerned
Old Nov 28, 2004 | 11:28 AM
bambooluv's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (ek9t)
Damn Tom thats some nice work man...is that for the hotrod car you are building? If so any more pics of it?
sorry to get offtopic...
Old Nov 28, 2004 | 12:02 PM
hondaguyef's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (bambooluv)
Jared,
Could you post a few pics of yours installed? (if you have any). Thanks.
Phil
Old Nov 28, 2004 | 06:51 PM
fulldragcrx's Avatar
i have them on my crx drag car. havent run with them yet though. they donot fit correctly on a EF need to be shortened, which i guess is better that need to be lenghtened. if any one knows how much to shorten them on a EF please post it.
Old Oct 21, 2008 | 03:46 PM
rallyeman's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (fulldragcrx)
Damn , both SRR and Comp.Eng. stopped producing those kits...:-(
Old Oct 26, 2008 | 10:33 AM
Justin Jones's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (rallyeman)
wow back from the dead...
I have a competition engineering kit... For a street car it really sucks to lose the steering radius. I had my dad sitting shotgun in my EG yesterday and I attempted a super easy U turn on a wide undivided highway and I had to do a three point turn instead... he was like "this thing's turning radius is worse than a 1 ton long box truck." He's basically right.
Kit was expensive too! The rod ends it comes with are the super shitty made in china ones. Definitely not Aurora, etc.
Oh well I plan on modifying the kit to fix the steering radius problem, upgrade to better rod ends, etc. Shouldn't be too difficult to improve the kit.
The stupid part of the kit is how it replaces part #1 in this diagram: http://www.hondaautomotivepart...R+BOX
From what I remember, the SRR kit kept that part OEM but for some reason Competition Engineering switched to the clevis bracket/rod end... Not only does that mess up your steering radius but it also makes the stock tie rod boots fit like garbage.
Old Oct 26, 2008 | 03:52 PM
srmofo's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Justin Jones)
thats your inner tie rod
Old Oct 27, 2008 | 02:44 PM
Full-Race Geoff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones &raquo;</TD></TR><TR><TD CLASS="quote">I have a competition engineering kit... For a street car it really sucks t...I plan on modifying the kit to fix the steering radius problem, upgrade to better rod ends, etc. Shouldn't be too difficult to improve the kit.</TD></TR></TABLE>
its almost impossible to fix these problems. The poor steering radius and the fubar'd susp geometry from their off-axis radius rods are inherent to the faulty design. its not something you can fix, it really makes a lot more sense to start over with a new traction bar
miller's Avatar
Default Re: Competition Engineering tie rod ends, yay or nay? (Full-Race Geoff)
geoff call me at the shop
