Rain + Leak = Water in Trunk
When it rains there is a leak somewhere in my car, but water is getting in the hatch around the spare tire. I can't tell where it is leaking. Has anyone else had this problem?
Is there any way to fix it? Redoing a seal or such?
could b leaking tail light gaskets..this is a common problem...buy a set of thick tail light gaskets from "Ragejed" on this board..also to get rid of the water drill a small hole to let it drain out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project H22DC4 »</TD></TR><TR><TD CLASS="quote">also to get rid of the water drill a small hole to let it drain out</TD></TR></TABLE>
Don't do that. Go to the link I posted.
Hey it may not be a leaky gasket. I had a lot of water coming in somewhere through the trunk last winter and it actually got so bad that it would soak the butts of anyone who sat in the back seat. After searching for a while, I discovered two little holes in the sheet metal below the rear strut assemblies. They're right near the rear wheel well, so when I drove over water the spray from the tires just went straight up and into the car. I doubt they're drainage holes because they are at a high point, not a lower point to be used to drain. The holes were left open after I had my car repainted, so there may have been tiny little pop-in seals to go there. Not a problem with the tail-lights for me. Check this before you buy anything that may be uneccesary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99civic_exSB »</TD></TR><TR><TD CLASS="quote">Haha. Funny title.
Post *****..pointless post?
</TD></TR></TABLE>Post *****..pointless post?
i have the saem problem. i was gonna sit in the car and have my friend run water over my car til i find the leak!! that was until i saw this thread.
I need to check that antenna idea. I have gutted most of the rear and it is raining right now, so I am going to go out in a little bit and see where it is coming in from. On the left side of the car (drivers side) I found two hoses/tubes that look like they are some kind of water run off. One of them is broken, so may be draining into the car.
Any tips on how to get rid of the mildew/mold smell? I have used half a case of lysol spray.
Ok ... this post is back from the dead. I finally tracked down the problem. It is a leaking tail-light gasket ... I am going to contact ragejed about buying a set of his custom gaskets to solve this problem.
effinnwackk
10
Jul 15, 2005 05:31 AM
