having trouble getting into 4th in higher rpms
Old Nov 11, 2003 | 04:12 PM
envious1320's Avatar
Default having trouble getting into 4th in higher rpms
for alittle while now i have had trouble shifting into 4th gear if i am in the higher rpm range. I was wondering would the clutch be the problem or is it the tranny itself. No other gears really have this problem just 4th and i have a 96 gsr with about 114k miles on it.
Old Nov 11, 2003 | 05:00 PM
fastfu's Avatar
Default Re: having trouble getting into 4th in higher rpms (envious1320)
im sorry to say it but it sounds like your 4th gear syncro is on its way out.
Old Nov 11, 2003 | 05:06 PM
87cquest's Avatar
synchro could be worn. clutch could be bad. have you tried adjusting the clutch pedal?
i had this problem on my car getting into second. i replaced the clutch with a SPEC stage 2, and I don't stick in any gears.
iheartmygsr
Transmission & Drivetrain
Sep 29, 2008 03:53 PM
TEGGRY
Mar 24, 2006 04:21 AM
EK_BackHatch
Mar 2, 2004 11:49 AM
sxecustoms
Dec 23, 2003 06:05 AM
ijjz
Apr 14, 2003 06:08 PM
