in which order do the skunk2 short shifter washers and gappers go on?
Old Nov 11, 2003 | 03:42 PM
Seedc2's Avatar
Default in which order do the skunk2 short shifter washers and gappers go on?
anybody have a pic... installing right now, it did not come with any instructions.
Old Nov 11, 2003 | 04:32 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: in which order do the skunk2 short shifter washers and gappers go on? (kendogg)
if you post a pic of the hardware you have i can probably tell you the order.
Old Nov 11, 2003 | 05:15 PM
Seedc2's Avatar
Default Re: in which order do the skunk2 short shifter washers and gappers go on? (PatrickGSR94)
need a better picture?
Old Nov 11, 2003 | 09:22 PM
TomO's Avatar
looks like the Metal bushing goes in the middle, the one spacer on each side, then the washers. HTH
Old Nov 11, 2003 | 10:26 PM
Black R's Avatar
25 Year Member
Default Re: (SonicGSR98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicGSR98 &raquo;</TD></TR><TR><TD CLASS="quote">looks like the Metal bushing goes in the middle, the one spacer on each side, then the washers. HTH</TD></TR></TABLE>
Correctamundo!
Old Nov 12, 2003 | 03:39 AM
ebelp's Avatar
Wow, that hardware is so much different than the stuff I got with my B&M. B&M supplies a bunch of rubber bushings...
Old Nov 12, 2003 | 06:53 AM
skunked's Avatar
Does it have bearings?
Modified by skunked at 7:18 PM 11/12/2003
Old Nov 12, 2003 | 10:10 AM
Seedc2's Avatar
Default Re: (skunked)
yea it has bearings
Old Nov 12, 2003 | 10:15 AM
skunked's Avatar
Default Re: (kendogg)
That's like mine but I didn't have the two smaller bushings. Maybe they are for the civic? The large bushing is to make up the difference in width of the shifter when you mount it to the shift linkage.
Old Nov 12, 2003 | 10:20 AM
Seedc2's Avatar
I don't understand why skunk2 doesnt provide instructions. Would have saved me a lot of time... I looked thru my helms and ran a bunch of searches here.. oh well its installed my way.. hopefully itll hold up. everything appears to be very good so far.
Modified by kendogg at 11:55 AM 11/12/2003
Old Nov 12, 2003 | 10:38 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kendogg &raquo;</TD></TR><TR><TD CLASS="quote">I don't understand why skunk2 doesnt provide instructions. Would have saved me a lot of time... I looked thru my helms and ran a bunch of searches here.. oh well its installed my way.. hopefull itll hold up. everything appears to be very good so far.</TD></TR></TABLE>
I know, how hard is it to throw together some instructions.
Old Nov 12, 2003 | 12:48 PM
beaterman's Avatar
go on team-integra.net and there is some instructions on there. its not for the skunk2 but it is very simillar
Old Apr 20, 2004 | 04:52 AM
Hairy Gorilla's Avatar
Default Re: in which order do the skunk2 short shifter washers and gappers go on? (beaterman)
back from the dead, but does anyone have a picture?
Old Apr 20, 2004 | 05:42 AM
beaterman's Avatar
Default Re: in which order do the skunk2 short shifter washers and gappers go on? (Tim Maryak)
here is the link to the team-integra.net article. its in the project section under performance.
http://www.team-integra.net/se...D=585
Old Apr 20, 2004 | 07:02 AM
Cool, well the only thing I am confused on is which side I should put the extra like half inch spacerI guess if I put it on the passenger side the shifter will lean in that direction, and If I put it on the driver side, it will lean more toward the driver, eh?
Old Apr 20, 2004 | 01:09 PM
Old Apr 20, 2004 | 02:46 PM
xplanetearth420x's Avatar
red X's dont help
need pic
Old Apr 20, 2004 | 02:50 PM
Comp97GSR's Avatar
Default Re: in which order do the skunk2 short shifter washers and gappers go on? (xplanetearth420x)
duuuude, look at the date of the original post.
Old Apr 20, 2004 | 06:05 PM
beaterman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tim Maryak &raquo;</TD></TR><TR><TD CLASS="quote">Cool, well the only thing I am confused on is which side I should put the extra like half inch spacerI guess if I put it on the passenger side the shifter will lean in that direction, and If I put it on the driver side, it will lean more toward the driver, eh?</TD></TR></TABLE>
it was in the thread i posted but here is the quote from team-integra
If you have the DC Short shifter (or any shifter that has a small "T" end and includes a spacer) then take out the small metal piece from the passengers side of the "T" end of the shifter and insert the bigger "spacer" (if it has a spacer) in its place
LeftLaneB*tch
Transmission & Drivetrain
10
Sep 6, 2014 01:13 PM
blkhondacivicSI
Dec 22, 2008 06:17 PM
hybrid98
Nov 10, 2006 07:59 AM
BigZ88
Mar 11, 2004 01:42 PM
TurboEg
Aug 11, 2003 07:50 AM
