ls vtec
Old Nov 11, 2003 | 12:47 PM
jaydmcrx's Avatar
Default ls vtec
I want to go ls vtec in my crx. I was going to use JE 12.5:1 pistons with eagle rods. Arp rod bolts. Is there anything else I should do to the bottom end to make it rev to 8500 safely other than that?? I mainly want a drag car, but i would like to go road racing and autocrossing too.
My head is going to be dpr p&p With skunk stage 2's Skunk springs and ti retainers. Skunk 2 intake mani and ported tb, B16a1 head. Just thought i'd let you guys know about that. I steared away from the type R swap because i think i can make more power using ls vtec for cheaper. What do you guys think?? Good set up? What should i change. And is there anything i should know while im building this set up Hopefully it will be done by the spring.
Oh yah and i am going to be running a block gurdle too. Any suggestions on where to buy one? What brand? etc...
Old Nov 11, 2003 | 01:04 PM
#8's Avatar
what kind of hp do you want? 200 plus?
this is my setup and i have 206 hp
ctr pistons
knife edged the crank
toda flywheel
toda cams
toda cam gears
itr intake manifold
toda springs retainers
hondata stage 3 w p28 ecu
theres more goods that i have with this setup,like intake clutch ect...
but this givesyou an idea of what kind of gains you can get with building an lsvtec
Old Nov 11, 2003 | 01:45 PM
71 mgb's Avatar
Default Re: ls vtec (jaydmcrx)
what pistons and head are you using? if you are running 12:5:1 on the street i sure hope u have 93+ octane whare your live..
Old Nov 11, 2003 | 03:26 PM
jaydmcrx's Avatar
yah we have 93 octane here. And I want to use je pistons. B16a1 head. But i think i may step it down to 12:1 pistons maybe a bigger bore or get it sleeved and bore it to 86mm. I dunno yet. But you are making really good power with your ctr's maybe ill go that route
200 whp is my goal. And 12.6 in the 1/4 with slicks.
marshall12395
Feb 23, 2015 03:29 PM
cleanazcoupe
Sep 14, 2010 03:39 PM
inline racing
57
Jan 8, 2009 03:12 AM
95BoostedEJ1
Oct 7, 2008 04:08 AM
cars101
Apr 21, 2006 08:05 PM
