problem w/ LS conversion in 91 hatch
My revs cut out at 3000 rpms. I've changed the ECU, distributor, wires and plugs and i can't seem to figure out the problem. If anyone has any ideas or have seen this before please let me know because i can't figure it out.
I checked the codes and all i'm getting is a 1 and 4. those are O2 sensor and crank angle i dont believe thats gonna control my rev limiter. i'm pretty sure i have all of my vaccums lines right. i'm really stuck on this one.
Yes, your ecu can't operate the engine properly unless it knows the position of the crankshaft. You need to find out if it’s wired up correctly and/or if the sensor itself is working right.
Give your ecu every thing it needs to run your engine right and it will.
...:::MaRk:::...
Jul 16, 2008 07:33 PM
ALL IMPORT
May 14, 2005 06:29 AM
