How do i take my dash trim out of my 93 ex
Old Nov 11, 2003 | 09:29 AM
tfalconier's Avatar
Default How do i take my dash trim out of my 93 ex
how do i take the dash trim out of my 93 ex, the trim around the heater controls and steering wheel, and the trim around the gauges?
Old Nov 11, 2003 | 09:50 AM
cxSHOE's Avatar
Default Re: How do i take my dash trim out of my 93 ex (tfalconier)
look in sig.
Old Nov 11, 2003 | 10:10 AM
NonovUrbizniz's Avatar
Loved
the "trim" around the heater controls isn't trim... it's part of the dash... it doesn't get removed...
the guage pod trim comes out with 2 screws on the underside of the top of the trim... (point both your hands at the guage like a gun (thumb up, pointer forward)) and the two screws are where your thumbs are pointing...
Then you need to CAREFULLY remove the hazard switch (by prying under it with a VERY fine tipped screwdriver (the smaller the better)... there should be another screw under there... then you just pry out the trim (be careful though the clips are realatively fragile (although if you snap them it's not the biggest deal the screws hold it in sufficiently)).
If you search I know there's a good write up on it somewhere with pictures to make it more clear...
ALso the helms in the above posters' sig will be the most help.
ratchetej1
Oct 31, 2017 06:51 PM
rivaladversary
15
Oct 2, 2009 04:10 AM
sugarplum
Jul 11, 2004 08:15 AM
tfalconier
Nov 23, 2003 12:24 PM
tfalconier
Nov 6, 2003 06:32 PM
