suspension issues
Old Nov 11, 2003 | 08:35 AM
abeaujuin's Avatar
Default suspension issues
I installed a suspension techniques rear lower sway bar. I had no control of the vehicle when switch lanes until, I went to nopi and they had me buy a front upper strut bar( neuspeed ) it helped alot, but I still don't have that stiff handleing Could it be that that Neuspeed upper strut bar isn't strong enough for the accord? I haven't installed the lower front swaybar because the accord comes with one already. Can someone shed some light here please?
Old Nov 11, 2003 | 09:48 AM
Nick H's Avatar
New User
Default Re: suspension issues (abeaujuin)
the swaybar on the accord in the front isn't as big as the aftermarket one...put it on...and also, what exactly are you asking?
Old Nov 11, 2003 | 11:24 AM
abeaujuin's Avatar
Default Re: suspension issues (Nick H)
I want a stiffer handle. It still sways left to right after quickly changing lanes.
Old Nov 11, 2003 | 11:38 AM
spankey167's Avatar
Have you torqued down the endlinks to correct specified specs? Install the front sway as well. You might want to go with a hyper flex master bushing kit from energy suspension. I'm getting it done today
Old Nov 11, 2003 | 01:20 PM
azian21485's Avatar
are you on stock springs?
Old Nov 12, 2003 | 06:51 AM
abeaujuin's Avatar
Default Re: suspension issues (azian21485)
I am using ebach 1.8 sportlines. With tokico shocks and struts. The car still bouces alittle. it isn't as stiff as my Audi tt. I want the steering wheel to be really stiff and tight. I did torque the rear to factory specs. I can feel the rear working when I take corners it does a great job, but the wheel itself doesn't feel tight as it should. I don't want to waste money on the front lower sway bar if it isn't going to help with that.
Old Nov 12, 2003 | 06:55 AM
spankey167's Avatar
I would think polyurethang bushings from Energy suspension, if better cornering is what you want.
loup05
Suspension & Brakes
14
Apr 18, 2006 01:45 PM
buzzboy8
Dec 28, 2004 09:28 AM
lazyxazianxboi
Sep 23, 2004 01:33 PM
ramz7887
Jul 19, 2003 11:54 AM
thehatchninja
10
Dec 23, 2002 12:08 AM
