I need to replace a lower balljoint got somequestions...
Old Nov 11, 2003 | 07:46 AM
sacredc0w69's Avatar
Default I need to replace a lower balljoint got somequestions...
Hey, i'm replacing the lower balljoint on the driver side on a 4th gen 1991 honda accord lx
i have the haynes manual but it doesn't tell u **** all about how to remove it and what to do, do i basically just unscrew the big bolt in the center of the brake and then just keep unscrewing till i get to hte balljoint? could anyone help me out with this? please...i need to do it asap and it aint to bad outside 2day so i was hoping to do it 2day
Old Nov 11, 2003 | 08:44 AM
nickg11111's Avatar
Default Re: I need to replace a lower balljoint got somequestions... (sacredc0w69)
which balljoint are you replacing? there is one on the end of the lower control arm, and one on the steering arm. i havent replaced mine yet, but i'm pretty sure they have to be pressed out. you may be able to use a BFH to get them out, but getting the new ones back in will be gay. i would take off your lower control arm/knuckle/hub assembly, and take it to a shop to have them press it out and the new one in. they should only charge something like 20 $ a side (tell them youll pay cash, that can usually make a difference). good luck.
Old Nov 11, 2003 | 10:26 AM
interesting....
I was planning on doing it with my mechanic and replacing the part on our own, he said its do able so i think we're just gonna do it manually.
Theres alot of movement in the control arm and that balljoint is really loose so hopefully we can do it alone..
Old Nov 11, 2003 | 11:36 AM
2000Accord5sp's Avatar
Default Re: (sacredc0w69)
If you're talking about the one at the end of the lower control arm (at the bottom of the brake rotor, after you take the clip out and unscrew the crown nut, you have to use a ball joint remover. basically you wedge it between the control arm and ball joint and hammer away...as it gets hammered in, it'll seperate the ball joint from the arm. They're pressed in and that's why it's so hard to take off
Old Nov 12, 2003 | 01:10 AM
aww alright thank u
androide016
Jan 8, 2008 11:10 AM
94vtirozguy
Suspension & Brakes
Apr 3, 2006 08:32 PM
lysol
Apr 27, 2004 10:41 AM
integra15
Nov 29, 2003 11:24 AM
illusion
Sep 10, 2002 05:13 PM
