Energy Suspension short shifter bushing... diagram
Old Nov 11, 2003 | 06:05 AM
Charlie Moua's Avatar
Default Energy Suspension short shifter bushing... diagram
...........EIDT hasport emailed me the answer, see last post !.......
I have a short shifter for a 94-00 gsr/integra.
I would like to know if I can infact use a ES short-shifter bushing for the EF chassie..... or should I get a ES bushing for the integra?
Also when I get the bushing.... WHAT part# will it be replacing?
....... does it come with any extra washers, spacers ect?
Modified by Charlie Moua at 7:40 AM 11/14/2003
Old Nov 11, 2003 | 06:21 AM
drjondurst's Avatar
get the EF bushings, the actual bushings never touch the actual shifter.. they fit onto stock EF parts.. they're #13 and 18 in the pic
Old Nov 11, 2003 | 08:08 AM
Quik89Si's Avatar
Default Re: (drjondurst)
Yup, 13 and 18. 13 is easier to replace, 18 is a bit more of a bitch if all the stuff is still in the car. You should be fine with the bushings for the EF, just like said above.
Alex
Old Nov 11, 2003 | 08:39 AM
Ef Whore's Avatar
Default Re: (Quik89Si)
Actually it's 16 and 18 that came with my Energy EF kit. It's called the shift stabilizer kit.
Old Nov 11, 2003 | 08:44 AM
Default Re: (Ef *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">Actually it's 16 and 18 that came with my Energy EF kit. It's called the shift stabilizer kit.</TD></TR></TABLE>
where to get it and how much?
does it come with extra washers bolts ect or just 2 red plastic urethane bushings?
Old Nov 11, 2003 | 08:56 AM
jc836's Avatar
Default Re: (Charlie Moua)
Want a set-I have them brand new. Drop me an e-mail.
I also have a brand new Neuspeed short shifter kit available.
Old Nov 11, 2003 | 08:59 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">
does it come with extra washers bolts ect or just 2 red plastic urethane bushings? </TD></TR></TABLE>
http://www.suspension.com Not sure on the price, but the kit rarely comes in red anymore, just black poly., and just the bushings no hardware.
Old Nov 11, 2003 | 09:03 AM
90civichbsi's Avatar
Default Re: (jc836)
if you are using a b series shift linkcage you will need a kit from a b series car such as a 90-93 integra, d series linkages use a different style bushing that connects to the tranny.
i had to buy a shifter set from a 90-93 integra along with the master kit for the ef so i could get that bushing
Old Nov 11, 2003 | 09:52 AM
Default Re: (90civichbsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90civichbsi &raquo;</TD></TR><TR><TD CLASS="quote">if you are using a b series shift linkcage you will need a kit from a b series car such as a 90-93 integra, d series linkages use a different style bushing that connects to the tranny.
i had to buy a shifter set from a 90-93 integra along with the master kit for the ef so i could get that bushing</TD></TR></TABLE>
WTF soo many different answers.
For the record this is what I have:
90 civic hb si
B18c1
hasport hydro tranny
hasport custom shiftlinkage
JG pro billet short shifter for 94+ integra or 92+ civic
Old Nov 11, 2003 | 03:27 PM
NCchris's Avatar
90 civic hb si
B18c1
JG pro billet short shifter for 94+ integra or 92+ civic </TD></TR></TABLE>
You need the bushing set for the integra, as stated above, the stabalizer bushing that attaches to the tranny is different between civic and integra. The other "bushing" is the same.
Integra tranny=integra shifter bushing set.
HTH
chris
Old Nov 11, 2003 | 03:35 PM
HandCommand's Avatar
What he said was correct. You need the shifter rod bushing...#16 for a B-series shift linkage. The bushing # 18 is the same for the Civic or Integra.
How is that HasPort Hydro conversion coming along? I love my ITR powered CRX with the JDM 4.7 FD LSD HYDRO tranny!!! Thanks to HaSport for coming out with a kit so I can finally run the tranny of my dreams in a CRX!!
Old Nov 12, 2003 | 04:29 AM
Default Re: (HandCommand)
so simply put the ES "stabilizer kit" comes with 2 bushing ....#16 & #18. nothing more.
I would use my OEM bolts and washers where/if needed ?
Which one to get:.................. 90-93 or 94-2000 ?
Where to buy?
Old Nov 12, 2003 | 06:39 AM
Ef Whore's Avatar
The 90-93 kit and the 94-up kit is the same exact bushings, regardless of a diff. part #. And yes 16 & 18 is all it comes with.
Old Nov 14, 2003 | 04:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">The 90-93 kit and the 94-up kit is the same exact bushings, regardless of a diff. part #. And yes 16 & 18 is all it comes with.</TD></TR></TABLE>
If that is correct then you are correct as well to say that you can use the DA bushings.
I emailed hasport about thier shift linkage.
Hello,
Before I order the shift linkage for my EF with swap. I wanted to know what kind of shift-linkage ends to you use. The reason why I ask is becuse I will be getting a short shifter along with the Energy Suspension "shifter stabilizer bushing kit". I wanted to know what kind of "ends" are on your shift linkage. If you use the DA style then I would need to get one for the DA. If not then i would stick with the EF bushing. I've spoken to guys that have modifyed (da shorten) shift linkage and they said they had to use the DA ES stabilizer kit cause their EF one did not seat correctly and have too much play with the DA shiftlinkage.
I just want to better prepare myself. Thanks much
Chia Neng
This is what they wrote back:
<U>Use 94-01 Integra bushings, they work the best.</U>
hasport
Old Nov 15, 2003 | 12:52 PM
All 87-2001 Integras use the same size shifter BUSHING. ( yes even the old skool Integras have the "bigger" B series size bushing in the stabilizer bar)
You get the bushing to fit the tranny you are using. B-series sized bushing if you are swapping a Bseries engine/tranny.
D-series size bushing if you are running a Dseries engine.
Why Acura used a Bseries sized bushing on the old school Integras is beyond me.
The HASPORT EF linkage does not come with the bushing, flat washer, beveled washer, bolt, etc.
I normally have these items in stock for my EF swaps. Here are the OEM part #'s......
B-series shifter bushing----54303-SB2-010
Beveled washer for bushing------54304-SK7-000
Flat washer for bushing--------54305-SA0-000
12mm Bolt ( certain length )-----95701-0801808
If you are local, I have all the parts needed. I can ship if need be.
Modified by HandCommand at 4:02 PM 11/15/2003
Old Nov 17, 2003 | 04:17 AM
damn tony you ROCK!
Old Nov 18, 2003 | 12:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">damn tony you ROCK!
No problem!!
Old Jul 22, 2004 | 09:10 AM
ironchef25's Avatar
i wish ive read this before buying my es master kit for my crx. bump for good info.
96electronH
31
Nov 19, 2007 07:31 PM
g2b2
Mar 29, 2007 06:57 AM
VtecAddict96
Apr 19, 2005 06:44 PM
JET_dC4
Nov 3, 2004 10:52 AM
ANGELIQUE
Feb 16, 2004 06:29 AM
