Swap done.... Need help??
Old Nov 10, 2003 | 11:46 PM
92CxHatchback's Avatar
Default Swap done.... Need help??
I just finished my Ls swap in my CX hatch. It is running fine. I didn't wire up the O2 sensor yet, so the check engine light is on. But another thing, it is sputtering at low RPm. Like when you hit the gas it puts out a little till the rpms get up there. Someone please tell me whats going on? And one more thing. It seems like i can't get my idle to stay at around 900 RPMs it wants to IDle pretty low. Thanks a lot
Old Nov 11, 2003 | 03:56 AM
wilsel's Avatar
Default Re: Swap done.... Need help?? (92CxHatchback)
Well it's not getting a reading from your 02 sensor. Those are symptoms of a bad 02 sensor. I would go ahead and wire it up, and then see how it runs after that. That's most likely the problem. If wiring the 02 sensor doesn't fix it, check all the vacumn hoses for leaks.
808DA
Jun 1, 2009 10:51 AM
nihad
Feb 28, 2007 07:53 PM
over-rev
Apr 19, 2006 12:43 PM
q.man06
Feb 25, 2006 07:54 PM
brettdacosta
Sep 14, 2005 09:45 AM
