dohc zc tranny in to crx 91 si please help
Old Nov 10, 2003 | 09:43 PM
mateencrx91's Avatar
Default dohc zc tranny in to crx 91 si please help
hello i have crx 91 si i am trying to put the dohc zc tranny in to the crx sohc motor. some one told me that i can use the 88 integra axles but 88 intregra alxes are short and when i turn it pops out of trans please help if u have any idea........
Old Nov 10, 2003 | 09:59 PM
TomO's Avatar
Just swap the ZC gears into the Si tranny case and then you can use the Si axels and be set.
Old Nov 10, 2003 | 10:05 PM
91civicDXdude's Avatar
or you could get the correct axles, which in this case would be the 90-93 integra axles and keep your intermediate shaft and equal length axles. Equal length axles help drastically with torque steer.
Old Nov 10, 2003 | 10:20 PM
DohcVtecCrx's Avatar
Default Re: (91civicDXdude)
I know this information is correct for a b series tranny, but are u sure it is for the dohc d series zc tranny? Not doubting you just making sure.
Old Nov 11, 2003 | 12:35 AM
davens's Avatar
Which intermediate shaft do you have? There are some specifics but 1990 Integra nonABS axles are the best place to start.
Old Nov 11, 2003 | 02:02 AM
AbaZ's Avatar
Default Re: dohc zc tranny in to crx 91 si please help (mateencrx91)
ZC manual Ishaft should work ok with 90-93 teg axles with dust seal removed on hub.
TH33G4MON3
10
Sep 11, 2005 02:30 PM
JDMVTEC
Nov 2, 2003 05:57 PM
pelotudo
Aug 20, 2002 10:40 PM
rasta420
Apr 27, 2002 07:14 PM
afstlsvtec
19
Mar 19, 2002 04:03 AM
