89 sohc ZC struggling at low RPMs
Old Nov 10, 2003 | 09:23 PM
rasta420's Avatar
Default 89 sohc ZC struggling at low RPMs
if i shift into any gear except first and start flooring it at around 1K rpms, it stays at 1K rpms for about 5 seconds before picking up any sort of speed. not the normal "honda's dont have torque" answer, cuz my other d16a6 does not behave like this at all. kinda annoying when i start in second gear or if im trying to save gas, and i have to keep downshifting to actually get anywhere.
what could cause this bogging?
Old Nov 10, 2003 | 09:29 PM
91civicEX's Avatar
Default Re: 89 sohc ZC struggling at low RPMs (rasta420)
check your cam timing or your CAS. is it throwing codes?
Old Nov 12, 2003 | 05:21 PM
rasta420's Avatar
Default Re: 89 sohc ZC struggling at low RPMs (91civicLX)
its throwing a code, but didnt check what it is yet. the code only comes on when im in gear, get off the gas, and cost for a lil bit. im guessing its the speedo sensor cuz my CRX did that when it had the VSS code.
whats the CAS?
Old Nov 12, 2003 | 07:00 PM
89s1's Avatar
if you ask me every SOHC honda 1.6 with or without vtec "struggles" at low rpms
sorry for the smart *** comment i just had to
Old Nov 12, 2003 | 07:31 PM
rasta420's Avatar
Default Re: 89 sohc ZC struggling at low RPMs (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 &raquo;</TD></TR><TR><TD CLASS="quote">not the normal "honda's dont have torque" answer</TD></TR></TABLE>
Old Nov 12, 2003 | 09:57 PM
91civicEX's Avatar
CAS= Crank Angle Sensor.
Code: 9, 8, and 4 could all have something to do with this
when the wires got disconnected on my car it had no low end power. i was slipping the clutch at 3000 just to get anywhere. i understand what your saying about not the normal dont have torque answer. for you the sensor should be on the cam gear side although i dont know where because mine is in the Dist.
Old Nov 13, 2003 | 01:04 AM
sohcvtec66
Guest
Posts: n/a
wow, thnx i used to have the same problam. so i said screw it and went JDM&gt;)
vtec is much nicer with some boost
Old Nov 13, 2003 | 07:03 AM
therealciviczc's Avatar
What is with the 2nd gear starts? Just curious.
Find out what that code is, because I would imagine that is where the problem is. I would think that should be the first step. I'm also going to guess crank or cam sensor, cam timing, ignitor/distributor issues as my first choices.
Old Nov 13, 2003 | 08:47 AM
rasta420's Avatar
Default Re: (therealciviczc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by therealciviczc &raquo;</TD></TR><TR><TD CLASS="quote">What is with the 2nd gear starts? Just curious.</TD></TR></TABLE>
besides trying to save gas? when im rolling to a stop, and say a light turns green, i usually try to stay away from shifting back into first while im rolling. even if i rev-match, the first gear synchro likes to go quickly on these trannies.
Old Nov 23, 2003 | 01:18 PM
sohcvtec66
Guest
Posts: n/a
d15b1 (std),, had blown gasket, head gasket, cracked valve cover, no exhaust, cracked raditor,leaked oil, and grinded, ans ping'ed the pycro's.. bogged down, spuddered like a ****.. the 1 week later put in a jdm swap..lol
DEPintheCurve
Oct 11, 2013 04:50 AM
low91rex
Nov 10, 2010 08:25 PM
Richard Noggin
Jun 13, 2006 01:03 PM
Creepshow S60
Oct 17, 2003 09:59 AM
BeEfiEBuNz
Nov 15, 2002 04:12 PM
