gsr ecu with skunk2 intake manifold
Old Nov 10, 2003 | 07:20 PM
envious1320's Avatar
Default gsr ecu with skunk2 intake manifold
I have a gsr and soon to have skunk2 intake manifold. Was wondering if you could just leave the gsr ecu on or would i need to switch to a diffrent ecu. If so which one? My car is obd2 so i would rather just switch to something where it will be plug and play.
Old Nov 10, 2003 | 07:23 PM
stick's Avatar
Default Re: gsr ecu with skunk2 intake manifold (envious1320)
u can still use ur stock ECU w/ skunk2 mani
Old Nov 10, 2003 | 08:04 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: gsr ecu with skunk2 intake manifold (stick)
I would highly recomend a P28 conversion.
Old Nov 10, 2003 | 08:19 PM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: gsr ecu with skunk2 intake manifold (Mr Milano)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano &raquo;</TD></TR><TR><TD CLASS="quote">I would highly recomend a P28 conversion.</TD></TR></TABLE> Well I ran my stock ECU (p72) with a skunk2 intake manifold and it worked out great, but after getting a set of skunk2 stage2 cams the p72 just isn't cutting it anymore, I am switching to a skunk2 chipped p28 Mr Milano is right about the recomendation of a p28 it will save you headaches later on down the road...
Old Nov 11, 2003 | 06:45 AM
onefstek's Avatar
if you switch to a p28 make sure its chipped to run your set up. A stock p28 will not do you any better than the p72. 98ctr
Old Nov 11, 2003 | 09:00 AM
BolivianDc2's Avatar
Default Re: (98ctr)
OBD2 p72 is fine, you'll car will get more power, but not be optimized.
Get a p28 with some sort of chip/program that seems like it would work for your car, or send 250-300 on Hondata and get it tuned.
Old Nov 11, 2003 | 10:29 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr &raquo;</TD></TR><TR><TD CLASS="quote">if you switch to a p28 make sure its chipped to run your set up. A stock p28 will not do you any better than the p72. 98ctr</TD></TR></TABLE>
Most assume that already.
Old Nov 11, 2003 | 11:01 AM
631 Teggy's Avatar
Default Re: (Mr Milano)
is a p28 ecu obd-1?
Old Nov 11, 2003 | 11:06 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">is a p28 ecu obd-1?</TD></TR></TABLE>
Si.
Old Nov 12, 2003 | 03:08 PM
TyPe_R_GuY's Avatar
Default Re: (Bolivianstrtwpn)
i would reccomend that you go Hondata in a P28 conversion, cause if you go with a universal chip like Jun,Skunk2, Mugen....or whatever, you are gonna need something to piggyback the ECU like the VAFC and then a B&M FPR and Gauge, then get some tuning, cause different chips have different fuel maps, some run really lean and others run very rich, and with Hondata the ECU will work well with your setup, but I wouldnt do this, until you do more mods to your car
Old Nov 16, 2003 | 02:26 AM
Downey's Avatar
a p72 will work but.. a chipped P28 would be much better. A del sol vtec P30 would work too, along with a P73 Type R ecu
Old Nov 16, 2003 | 03:51 AM
Junkiii Ek's Avatar
Default Re: (98ctr)
good idea...chip that P28 it'll be alot better than ur stock P72....
Old Nov 18, 2003 | 06:18 AM
mraudio13's Avatar
Default Re: (Junkiii Eg)
I have a question, Does the P28 support ABS. Or do you have to use a P72 to use the ABS on an obd-2 car?
Matt
Old Nov 18, 2003 | 06:23 AM
smnowell's Avatar
Default Re: (mraudio13)
I believe ABS is controlled by its own type of computer or control box. And with the P72 and the Skunk2 Manifold, you might notice some flat spots in your power curve. I used to have a P72 (until it was stolen ) and I didn't like it with my Skunk2 Manifold. I bought a chipped ECU from Kenji and it runs great
Old Nov 18, 2003 | 08:20 PM
E36 Guy's Avatar
Default Re: (b16a ferio)
sorry to put a question your thread but.... will a stock pr3 ecu be good for a b18c with skunk 2 mani? i cant get a p28 cuz im obd0 damnit
Old Nov 18, 2003 | 09:35 PM
Downey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a ferio &raquo;</TD></TR><TR><TD CLASS="quote">I believe ABS is controlled by its own type of computer or control box. And with the P72 and the Skunk2 Manifold, you might notice some flat spots in your power curve. I used to have a P72 (until it was stolen ) and I didn't like it with my Skunk2 Manifold. I bought a chipped ECU from Kenji and it runs great </TD></TR></TABLE>
yea true that. p72 with skunk2 manifold sucks! vtec kicks at 4400rpm and the car bogs. lots of flat spots all over the powerband. Hondata P28 is what u need.
Old Nov 20, 2003 | 09:40 AM
E36 Guy's Avatar
Default Re: (Downey)
up
Old Nov 20, 2003 | 11:50 AM
iH8RICERZ's Avatar
Default Re: (b18c3)
I have a 94 GSR w/ a skunk2 IM as well..but my gsr is already obd1. If you want some dyno numbers in comparing the stock ecu over my custom all motor chipped p28 ecu...click on my vouch thread...the guy who dynoed my car posted up my dyno graph....actually, i'll just post it here......
the blue line indicated my dyno run w/ the chipped p28 ecu......For highway use, I always use my stock p72 just because its a gas saver..but doesnt perform all that great....if you have any questions regarding chipped p28 ecu's and/or obd2-1 conversion harness..., feel free to PM me
BTW: no tuning was done to my car except for cam gears (VAFC would help crank out a couple more ponies and have a smoother power ban....but adj the cam gears didnt really help at all either. mods to my car at the time: aem short ram, skunk2 IM, ctr intake cam, skunk2 cam gears, dc 4-2-1 header, greddy sp cat back. Custom all motor chipped p28 ecu as well
thanks
-Jason
WHITE DEATH
Jan 18, 2005 02:14 PM
jay_powell
Jun 13, 2004 11:12 AM
xplanetearth420x
Apr 22, 2004 09:28 PM
SiR HatchAlot
Oct 1, 2003 12:26 AM
