Web cams
I am looking into buying a web cam. I heard that they have good hp increase, and cut your times hard. I just don't understand the specs about them (valve lift, duration in degrees, grind numbers, and duration at .05 in degrees.). I want to get the most extreme cam without having to get new valves and springs and all that other shat. Can someond help me find my cam and help understand cams a little better, and if you have a web cam in your EF tell me the specs. Thanks fellas
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoebox »</TD></TR><TR><TD CLASS="quote">I just don't understand the specs about them (valve lift, duration in degrees, grind numbers, and duration at .05 in degrees.). I want to get the most extreme cam without having to get new valves and springs and all that other shat. </TD></TR></TABLE>
what dont you understand about the cam specs?
is this for street use or for drag/autox/roadcoarse???
heres a list of the different cams/manufacturers for the d16a6 to compare by...https://honda-tech.com/zerothread?id=427814
I8ayellowcrayon
Apr 26, 2007 05:45 PM
