Honda S2000 Honda S2000
Noise with clutch in/out
Old Nov 10, 2003 | 06:26 PM
Razor's Avatar
Default Noise with clutch in/out
At idle and in neutral, is it normal for the car to get quieter when you push in the clutch as apposed to having it out. the noise isn't very obvious and loud, but you can hear it if you listen for it. i hope its normal and its just the noisy throwout bearing. what do you guys think?
Old Nov 10, 2003 | 06:58 PM
chris@inlinepro's Avatar
if it is a growling noise when in idle it probebly is the throwout bearing. lol i go to lincoln tech in Columbia MD and im in "manual tranny & driveline" class right now so ill ask the instructor for you tomorrow and let you know for sure
crxONcrack's Avatar
Default Re: Noise with clutch in/out (Razor)
noisy bearing..........under warranty though..........make them check it out
Old Nov 10, 2003 | 08:38 PM
J T*'s Avatar
Default Re: Noise with clutch in/out (crxONcrack)
Mine has made that noise since it was new. It now has 30k miles on it.
Everyone has told me it's the throwout bearing but then I've been told that the throwout bearing makes noise when you press the clutch in..... I'm replacing my clutch soon thouse so maybe the noise will go away.
Just get a Spoon exhaust and you won't even be able to hear ....anything anymore.
Old Nov 11, 2003 | 02:30 AM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">At idle and in neutral, is it normal for the car to get quieter when you push in the clutch as apposed to having it out. the noise isn't very obvious and loud, but you can hear it if you listen for it. i hope its normal and its just the noisy throwout bearing. what do you guys think?</TD></TR></TABLE>
no, it is not the throwout bearing. When you have the clutch engages in neutral, the crank is still spinning as well as internals in the tranny. That's the noise you are hearing, the spinning shafts in the tranny (sorry for the lack of a technical term for spinning shafts in tranny) but this is normal. Again, it is not a faulty throwout bearing.
Old Nov 11, 2003 | 08:41 AM
Razor's Avatar
Default Re: Noise with clutch in/out (vapor)
ok thanks for the explanation vapor. as long as its normal, im happy. the noise doesnt bother me at all, it barely audible.
C-West Civic
Sep 10, 2013 04:58 AM
shermanyang
Dec 1, 2012 11:24 AM
JDMtype Eg6
May 29, 2006 03:45 AM
avex
Oct 26, 2003 09:54 AM
RS1995
Jan 6, 2002 12:26 PM
