D16Y8 manifold swap
So far I have noticed no PCV port on the Y8, and no IAT bung. These limitations will have to be overcome.
Basically I took the mani off because I am dropping in some DSM injectors, and I hear I have to dremel the injector seats...
-PHiZ
-PHiZ
On the Y8 the IAT went into the intake piping.
The PCV from the valve cover also went into the intake piping right after the IAT sensor.
The PCV from the block goes up inbetween the middle of the runners and connects to the IM in the center front.
why are you increasing the injector size? are you pushing over 200whp already?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">On the Y8 the IAT went into the intake piping.
why are you increasing the injector size? are you pushing over 200whp already?</TD></TR></TABLE>
where is this PCV from the block?
