92-95 EX Flywheel fit 89 CRX Si Tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">flywheel goes on engine, not on transmission - axles, depends on what model axles in what model car</TD></TR></TABLE>
I know that...it still has to fit the transmission though...and they are 88 CRX Si axles and will be going in an 89 CRX Si
Axles should work fine. I believe you can use that flywheel as well. I think the flywheel that won't work is the 88.Try looking up part numbers and double check if the 89 is different from the 90+
i had the same question kind of ...
i have a 90 crx tranny
an 89 flywheel
and an 90-91 act clutch ..
will this work ? .. i wasnt sure if the flywheel would hook up right or not .. i know the 88 doesnt ....
thanx
an 89 flywheel
thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vera »</TD></TR><TR><TD CLASS="quote">i had the same question kind of ...
an 89 flywheel
thanx</TD></TR></TABLE>
No. 88,89,90-00 flywheels are different. 90-00 are bigger than 88, 89 is slightly bigger than 88.
Modified by Mr. S at 12:51 PM 11/12/2003
an 89 flywheel
Sorry for the confusing post.
What I mean to say was that:
88 flywheels have a smaller clutch (190mm)
89 flywheels have a larger clutch (200mm)
and 90-00 have the largest (210mm)
Not 100 percent sure on the exact mm measurements here, but you get the idea.
KevronsEG
Jan 14, 2003 08:48 AM
