b18A ECU on a B18B1
Old Nov 10, 2003 | 02:33 PM
superstud's Avatar
Default b18A ECU on a B18B1
will this work temporarily? reason: sending ecu to get socketed for hondata, still need to drive car, can borrow b18a ecu from a friends 92GS. thanks for any replies!!
Old Nov 10, 2003 | 02:59 PM
91tegrals's Avatar
should work i think the 92 is a obd1 and should be youre car i think..
Old Nov 10, 2003 | 03:40 PM
jonsteR's Avatar
Default Re: b18A ECU on a B18B1 (superstud)
They should work, as long as they're the same OBD. I've used b18a and b18b ecus in my car.
Old Nov 10, 2003 | 04:50 PM
Mr. Softee's Avatar
Default Re: b18A ECU on a B18B1 (jonsteR)
OH MY GOD NO!!!111 RUNNN!111
j/k its fine.
Old Nov 10, 2003 | 06:07 PM
gsrinstyle's Avatar
Default Re: b18A ECU on a B18B1 (94goldjungsr)
could u do this backwards? could i directly plug in a b18b on a b18a car???
Old Nov 10, 2003 | 06:35 PM
Newman's Avatar
New User
Default Re: b18A ECU on a B18B1 (gsrinstyle)
Hell, you can run a DX computer on your LS motor if you really needed/wanted to, to get by and drive the car. Just as long as you have an OBD-1 computer for an OBD-1 car, or an OBD-0 ECU for an OBD-0 car (same applies for OBD-2 & 2.5), then you're set. When you say "B18A" and B18B" most people think of B18A as 90-91, which is OBD-0 and B18B as 94+ Integra (OBD-1 or OBD-2), and then the ECUs are not interchangable in those year of cars, but the longblocks are the same. Just make sure you get a compatible ECU that'll plug into your car.
Old Nov 11, 2003 | 01:07 AM
superstud's Avatar
awesome! thanks for the info!!
heeltoehonda
Mar 17, 2010 07:51 AM
88CReXin
May 24, 2007 11:45 AM
Hoppa
Jul 21, 2006 03:00 PM
huge230
Jun 25, 2005 12:27 PM
JCracer723
Dec 1, 2003 12:12 PM
