91-93 vs 94-01 ls..?
Old Nov 10, 2003 | 12:44 PM
tencan's Avatar
Default 91-93 vs 94-01 ls..?
what are the differences between 94-01 LS and the pre 94 models...i figure there must be a diff, is it something like a knock sensor or something small like that or is the difference as great as for example...93 tranni wont fit on 94 block...i want to get a ls and i see like 91's for like 400-500 and i see 97's for like 750-850(excluding transmissions) which should i go with...besides the fact that ones obdI and the other is obdII , and ones like half the price than the other are there any other differences?
Old Nov 10, 2003 | 01:54 PM
EdoMoto's Avatar
Default Re: 91-93 vs 94-01 ls..? (sodacan)
well they are the same except the 91 might have 200K miles and the 97 might have 80k miles. Thats the difference old and new.
Old Nov 10, 2003 | 02:53 PM
xSCTYGx's Avatar
Default Re: 91-93 vs 94-01 ls..? (ITAIntegraLS)
couple ponnies difference...more miles with 90-93 motors most likely..the 90-91 motors are obd0 by the way and 92-95 are obd1 and so on...just to let u know!
Old Nov 10, 2003 | 02:58 PM
91tegrals's Avatar
90-93 130hp 124tq
94-2001 142hp same tq
90-93 cable trans
94-2001 hydralic trans thats the big differences i can think of..
Old Nov 10, 2003 | 03:17 PM
HHogan's Avatar
Default Re: (91tegrals)
90-91 is 130 @ 6000 RPM / 121 lbs-ft
92-93 is 140 @ 6300 RPM / 126 lbs-ft
Old Nov 10, 2003 | 06:43 PM
Newman's Avatar
New User
Default Re: 91-93 vs 94-01 ls..? (2Gen91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2Gen91Teg &raquo;</TD></TR><TR><TD CLASS="quote">couple ponnies difference...more miles with 90-93 motors most likely..the 90-91 motors are obd0 by the way and 92-95 are obd1 and so on...just to let u know!</TD></TR></TABLE>
The B18B motors have a little more power due to the intake manifold. Longblocks are the same otherwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HHogan &raquo;</TD></TR><TR><TD CLASS="quote">90-91 is 130 @ 6000 RPM / 121 lbs-ft
That's mainly because of the YS1 LS tranny gear ratios (vs. the A1 tranny gear ratios) and OBD-0 vs. OBD-1 electronics.
Old Nov 10, 2003 | 06:53 PM
VTECisSeXY's Avatar
*insert here*
Default Re: 91-93 vs 94-01 ls..? (Newman)
I would hafta disagree with you newman. Maybe the gearing is slightly different and of course yes, the obd difference. But the <U>major</U> factor of the ~10hp is the cams. the 92-93 are definetly larger.
Modified by VTECisSeXY at 9:41 AM 11/11/2003
Old Nov 10, 2003 | 10:04 PM
riceball777's Avatar
90-91 = 130hp obd0
92-95= 140 hp obd 1
all in all they are pretty much the same speed
Old Nov 10, 2003 | 10:09 PM
HHogan's Avatar
Default Re: 91-93 vs 94-01 ls..? (VTECisSeXY)
Newman said it was the tranny, I just stated the #s
Old Nov 11, 2003 | 05:42 AM
VTECisSeXY's Avatar
*insert here*
Default Re: 91-93 vs 94-01 ls..? (HHogan)
i corrected it, sorry hhogan
Old Nov 11, 2003 | 09:08 AM
2ndGenTeg22's Avatar
Well, G3's are heavier than G2's, but the ten extra ponies might just even it out....Theyre almost identical...
Old Nov 11, 2003 | 09:50 AM
alterboy82's Avatar
90-91 cable trans
92-00 hydro...
I need a cable tranny, ef swap...duh
skidmarkroyalty
14
Mar 7, 2012 09:03 AM
92integraVTECgsr
Sep 8, 2005 06:10 AM
LS_crxjhm
Aug 11, 2004 09:51 PM
slowr6
May 12, 2004 11:06 AM
Tiamat-blue
Mar 20, 2003 04:57 AM
