Boring out d16-->w/b16 pistons 1.8 liter
Old Nov 10, 2003 | 12:26 PM
Soccerking3000's Avatar
Default Boring out d16-->w/b16 pistons 1.8 liter
okay is it possible to bore out a d16 and put b16 pistons et cetera in it and make it a 1.8 liter, i think it would be feasible but i want to makes ure can anyone help e out???
Old Nov 10, 2003 | 12:36 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Boring out d16-->w/b16 pistons 1.8 liter (Soccerking3000)
Sounds like a stretch to me; the bore size would definately be killing the water jackets' cooling efficiency and it probably wouldn't line up with the head's combustion chambers.
I can't say that 100%, though, so this is a bump for more knowledge.
Old Nov 10, 2003 | 12:43 PM
2000blackgsr's Avatar
Default Re: Boring out d16-->w/b16 pistons 1.8 liter (Archidictus)
I've heard of boring out a D-series and putting LS rods in, so I imagine LS pistons would go in too. I'll search for the thread.
Old Nov 10, 2003 | 01:22 PM
Ricey McRicerton's Avatar
Default Re: Boring out d16-->w/b16 pistons 1.8 liter (96coupe)
I started on this project a while back. Here is the thread I started about it a while back.
2.0 D series
https://honda-tech.com/zerothread?id=523972
Old Nov 10, 2003 | 02:09 PM
SOHC_MShue's Avatar
Default Re: Boring out d16-->w/b16 pistons 1.8 liter (Ricey McRicerton)
what ever happened to your 2.0 D series? That would have been sweet.
Old Nov 10, 2003 | 06:23 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96coupe &raquo;</TD></TR><TR><TD CLASS="quote">I've heard of boring out a D-series and putting LS rods in, so I imagine LS pistons would go in too. I'll search for the thread.
Very different. The LS rods work because they are the same length as the stock d-series rods. People use them because they are stronger than stock d-series rods.
Old Nov 10, 2003 | 06:28 PM
Default Re: Boring out d16-->w/b16 pistons 1.8 liter (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">what ever happened to your 2.0 D series? That would have been sweet.</TD></TR></TABLE>
It's still a plan in progress. I opted for FI first, and then later on when I get some more money I'll be doing a 1.9 D series (2.0 is'nt going to work). When I finally do get it done, I'll post it all up here!
Old Nov 10, 2003 | 08:03 PM
Evs-One's Avatar
Solbros Owns Me
I might try this soon as well
AEBS sleeves installed for 480
Old Nov 10, 2003 | 08:07 PM
RyanEJ8's Avatar
Rod length and bore are two different things.
It would be possible to put B16 pistons in a D16 block, because a D16 can be sleeved to 81mm. The compression would be very high, especially if using a Y8 head. I would just use an aftermarket piston if I was putting the money in for sleeving on a build up.
ghostskinner
May 29, 2005 04:55 PM
specie
Oct 13, 2003 11:34 PM
wm5holla
17
Oct 1, 2003 12:41 AM
yaya
May 26, 2003 04:35 PM
hotintegranights
May 13, 2003 11:50 AM
