what's your suspension setup?
Old Nov 10, 2003 | 11:08 AM
seannabend's Avatar
Default what's your suspension setup?
I'm about to get a set of teg rear LCA's and then it's going to be an all out suspension fest on my EG....
my current setup is as follows
springs: stock
shocks: stock
F sway: none
R sway: none
F upper tie bar: none
R upper tie bar: none
F lower tie bar: none
R lower tie bar: none
camber kit: none
wheels: 14" HX alloys
rubber: Goodyear Regatta 2 [all season]
overall impression: Sucks ***! except for the wheels and tires, at least the car is pretty light but I can't wait to upgrade the suspension
Old Nov 10, 2003 | 11:12 AM
Damon B.'s Avatar
Default Re: what's your suspension setup? (seannabend)
I like my set-up, not done though.stock type r front upper bar, mugen rear upper bar, tein flex coilovers, z-speed lower tie, stock rear and front sway, 15 inch volk ce28n's on yokohama es100's or si wheels on potenza re730's.
Modified by CleanSi at 9:36 PM 11/10/2003
Old Nov 10, 2003 | 11:15 AM
seannabend's Avatar
If I had to order all parts tomorrow my setup would be as follows [probably do this in phases]
springs: Eibach pro-kit
shocks: Tociko Illumina
F sway: none unless needed, then stock sir2 bar
R sway: comptech 22mm
F upper tie bar: Neuspeed unadjustable
R upper tie bar: type-R style off ebay
F lower tie bar: undecided on this
R lower tie bar: comptech [tiebar/subframe support]
camber kit: none- unless tires start wearing unevenly
wheels: 14" HX alloys [winter]
rubber: Goodyear Regatta 2 [winter]
wheels: 15" rota slips [summer]
rubber: Falken Azenis [summer]
Old Nov 10, 2003 | 11:17 AM
VX's Avatar
VX
My current setup is as follows:
Springs:
F: Eibach ERS 800.250.375 w/ Ground-Control Koni adapters.
R: Eibach ERS 800.250.425 w/ Ground-Control Koni adapters.
Shocks:
F: Neuspeed Koni Yellow's. w/ Ground-Control upper mounts.
R: Neuspeed Koni Yellow's.
F sway: none
R sway: none
F upper strut bar: none
R upper strut bar: none
Camber kit:
F: Skunk2 Racing.
R: SRR.
Wheels: 13" diameter, 5" width, +45mm offset. Stock VX Wheels.
Rubber: Yokohama AVID T4 (185/70/13).
Old Nov 10, 2003 | 11:31 AM
wilsel's Avatar
Default Re: what's your suspension setup? (VX)
Springs: Sprint
Shocks : Stock (upgrading to Koni Yellows soon)
Bushings: Energy Suspension Master Kit (with trailing arm bushings)
FU, Strut Bar: Neuspeed
RL, Tie Bar: Skunk 2
Rear Sway Bar: ITRw/beaks kit
Front Sway: Stock EX
Tires: 17" Visa (never heard of them either)
Rear Disc Swap
Old Nov 10, 2003 | 11:54 AM
Navid OG's Avatar
Default Re: what's your suspension setup? (wilsel)
I have most of these but i need a few more products to finish...this is what it will be like:
Springs:
F: H&R Race.
R: H&R Race.
Shocks:
F: Koni Yellow's.
R: Koni Yellow's.
F sway: none
R sway: ST sway and Tie bar kit
F upper strut bar: ITR
R upper strut bar: no name but its nice and thick
R lower tie bar: already stated
Camber kit:
F: SPC
R: Washers
Old Nov 10, 2003 | 11:58 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seannabend &raquo;</TD></TR><TR><TD CLASS="quote">I'm about to get a set of teg rear LCA's and then it's going to be an all out suspension fest on my EG....
springs: stock
shocks: stock
F sway: none
R sway: none
camber kit: none
overall impression: Sucks ***! except for the wheels and tires, at least the car is pretty light but I can't wait to upgrade the suspension </TD></TR></TABLE>
see thread:
https://honda-tech.com/zerothread?id=671257
Old Nov 10, 2003 | 12:02 PM
Jason C SBB's Avatar
On my 2-door EK (HX)
In order of largest improvement to smallest:
- Koni yellows
- ST rear swaybar
- Yokohama ES100 tires on stock lightweight 14" alloys
- swap UCAs
- ES shifter bushings (improves driving pleasure, not handling)
- H&R OE sport springs (I now set Konis to 1" lower than stock
- Superpro bushings in front LCA rear location
- front shock tower bar from '00 Si
- ES steering rack bushings
Only the spring swap degraded ride quality, and the ride quality degradation was larger than the improvement in handling.
Car is now reasonably fun to drive, corners pretty well. On throttle lift I can get the rear to step out. I probably have to install the front ST swaybar that came with the set. Good thing those ES100's are very progressive!
Modified by Jason C SBB at 9:14 PM 11/10/2003
Old Nov 10, 2003 | 12:04 PM
snowboarderguy44's Avatar
Springs: Neuspeed Race
Shocks: Koni yellows 'ITR'
F Upper Strut: ebay mugen style matted to CTR
R Upper Strut: EM Racing
F Lower Strut: Top Speed Auto H-bar
R Lower Strut: DC sports
Camber F: Skunk2
Camber R: waiting for SSR ball-bearing to be released
Sway F: GSR
Sway R: ITR 23mm w/beaks
LCA's R: ITR
:::currently waiting for the SSR speherical bearing rods to be released, and goin to upgrade to triangulation bars from EM Racing
Old Nov 10, 2003 | 12:08 PM
VX's Avatar
VX
Default Re: what's your suspension setup? (Jason C SBB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason C SBB &raquo;</TD></TR><TR><TD CLASS="quote">- swap upper LCAs</TD></TR></TABLE>
Old Nov 10, 2003 | 12:12 PM
JICEK9's Avatar
JIC FLTA2 on all four corners
JIC carbon fiber strut bar front/rear
JIC lower tie bar front/rear
Suspension Tech sway bar front/rear (1in front / 3/4in rear)
Old Nov 10, 2003 | 12:14 PM
phantom_sol's Avatar
eibach 25mm front sway
eibach 17 mm rear sway
tokiko blues
H&R sport springs
generic front upper strut bar
cusco front lower tie bar
emracing rear upper strut bar
emracing trunk bar
emracing triangulated trunk bar
wheels: Del sol Fat fives
tires: dunlop sp-a2
ingalls font camber kit.
itr cross member brace
pending:
tires: azenis for my rota shitstrems 15"
saving for:
tein ss for integra (higher springrates)
prothane total kit (but confused because del sol is bastard car. which one do i get?)
neuspeed uper strut bar.
any decent rear lower tie bar.
Old Nov 10, 2003 | 12:27 PM
Archidictus's Avatar
Unceasing Measure
Default Re: what's your suspension setup? (phantom_sol)
Springs: Tein S-Tech
Shocks: KYB AGX (1 front, 4 rear)
F Upper Strut: nope
R Upper Strut: fuckit
F Lower tie: nada
R Lower tie: Ebay generic
Sway F: stock Civic Si (1993)
Sway R: none yet (Comptech or SRR in the near future)
LCA's R: D2 aluminum with urethane bushings
Old Nov 10, 2003 | 01:12 PM
Carlo's Avatar
SRR LCA
SRR Camber kit
SRR Toe kit
96 ITR 15x6 wheels
Falken Azenis 205/50/15
Not finished yet, still debating on which coilovers, sway bar, etc.
Old Nov 10, 2003 | 01:21 PM
WangChung's Avatar
Default Re: (Carlo)
-springs
F:dropzone 350 lb/in (coilsleeve)
R:dropzone 450 lb/in (coilsleeve)
-Shocks
F/R:tokico illumina 5-ways
-bars
F:ebay front strut bar
R:Ebay bar (waitning on endlinks and beaks so i can put on my CTR rear sway)
-Wheels
F/R: 14"x6" steelies
-tires
F/R: 195/60/14 falken azenis
may sound cheap, but it handles so well!!
2000blackgsr's Avatar
Default Re: (Carlo)
Car: 96 HX
H&R Cup Kit
Nuespeed Front Upper Strut
Cheap All-Season Tires on HX wheels since its starting to get cold.
Old Nov 10, 2003 | 01:32 PM
PRoJecTSLeePaLoT's Avatar
Went from skunk2 coilovers for a 94-01 integra with tokico illuminas to Tein Flex. Gotta get some upper struts and lower tie bars but just waiting for the best deals. Rolling on 95 gsr rims...kumho tires hahah... gonna get some new ones soon. Looking at some Falken Azenis...
Old Nov 10, 2003 | 01:47 PM
ddong2lee's Avatar
tokico hp shocks and tokico springs all around about 1.75" drop
15" rota circuit 8's wrapped with kumho escta supras
Old Nov 10, 2003 | 02:16 PM
EG TYPE-R's Avatar
Default Re: what's your suspension setup? (ddong2lee)
jic flta2
mugen trailing arm bushings.
srr rear camber kit in the mail
hx rims with yokohama es 100 tires
still deciding on strut bars
so far its very nice
Old Nov 10, 2003 | 02:44 PM
ek nine's Avatar
i have a ek9 and rolling on tein ss w/ a 2.25 inch drop. everything else is pretty stock.... i still need to work on my suspensions.
Old Nov 10, 2003 | 02:45 PM
SOHC_MShue's Avatar
Default Re: what's your suspension setup? (EG TYPE-R)
I have h&r sport springs with kyb agx shocks. 15" slipstreams with shitty kuhmo 712 tires. Will have azenis soon
Old Nov 10, 2003 | 02:53 PM
Autoxjoe's Avatar
GC coilovers 500f 375r
KYB agx (always on 4 to minimize bouncing)
stock Si front sway bar
progress 22mm rear sway
skunk 2 uca's
GC front upper mounts
ES bushings
neuspeed front strut bar
4pt roll bar as a rear strut bar
konig heliums
azenes
shes lowered .25" because i would rather look like a 4x4 then have my shocks bottom out anymore
someday-shortened, revalved koni's on 425s f &r
Ek-Xang
Feb 4, 2010 12:30 AM
1 Special CTR
Dec 19, 2004 02:18 AM
abuck
Aug 5, 2004 01:46 PM
fungus@school
11
Sep 1, 2001 02:27 AM
ZUL8R
Aug 24, 2001 10:05 AM
