12 sec. CRX
Old Nov 10, 2003 | 09:25 AM
zero2sxity's Avatar
Default 12 sec. CRX
Im wanting to make my CRX, run 12's. I have a B18C1. What can i do to make it run in the 12 sec. frame.
Old Nov 10, 2003 | 09:27 AM
manson's Avatar
Default Re: 12 sec. CRX (zero2sxity)
everything.
Old Nov 10, 2003 | 09:34 AM
turboZChatch's Avatar
Default Re: 12 sec. CRX (mansonclubpuir)
Firs you have to decide if you wanna go turbo or not if not then build the block sleave it pistons rods rings etc with 12.5.1 comp if your gonna go turbo do the same to the block but with like 9.5.1 comp and if your going all motor do skunk2 stage 2 cams valves springs and retainers should put you in he 12's remember fast is not cheap
Old Nov 10, 2003 | 09:38 AM
RiceRacist's Avatar
Default Re: 12 sec. CRX (turboZChatch)
Id gut the **** out of the car, try a good well known combo for low compression and throw a 125shot on there with the obvious i/h/e/ecu and slicks.
One of the cheapest combos
Old Nov 10, 2003 | 09:41 AM
MustangPunk302's Avatar
Make sure you don't detonate, about the best thing you can do with any build up, otherwise your build can go to **** within a spilt second...
Old Nov 10, 2003 | 09:46 AM
Rob!'s Avatar
Default Re: (MustangPunk302)
turbo y0...it depends...me personally would rather build it all motor instead of turbo...you gotta know what your doing if your tryin to build a 12 second crx. b18c is a good motor to do it with.
Old Nov 10, 2003 | 10:02 AM
0554's Avatar
Default Re: (EKsnatchback)
my buddy has a ls resleeved to 86mm runnin 12:1 compression with stock type r head. runnin a chipped pr3 with rc 440 injectors. and he ran 12.4 all motor with no traction in first or second with some 13'' slicks on. i cant remember the exact size of the slicks. car is roudy as hell.
Old Nov 10, 2003 | 11:17 AM
Malgerus's Avatar
Default Re: (88crex)
A friend of mine ran a 12.99 with a JDM B18C, I/H/E, Cams (I think) and slicks. Good driving = most important part.
Old Nov 10, 2003 | 12:33 PM
thrty8street's Avatar
what does your car run now with your current b18c1?
Old Nov 11, 2003 | 02:37 AM
goofball123321's Avatar
yeah turbo is the way to go, and gut the car too.
Old Nov 11, 2003 | 05:01 AM
Turbo Laser's Avatar
Default Re: (goofball123321)
Drag Turbo Kit (15-20psi)
Inline Pro headgasket
Apexi VAFC (hours of good tuning)
MSD btm
I'll assume you already have basic stuff like exhaust and suspension. You can do it for about $4500 with all new parts and a lot cheaper if you pick all this stuff up used
Old Nov 11, 2003 | 05:07 AM
Default Re: (nocarloser)
and I wouldn't gut the car .....there's only like 40 pounds of interior in a CRX anyway, lol. I would gut if it was my beater project race car, but otherwise keep the stock interior!
Old Nov 11, 2003 | 05:23 AM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crex &raquo;</TD></TR><TR><TD CLASS="quote">my buddy has a ls resleeved to 86mm runnin 12:1 compression with stock type r head. runnin a chipped pr3 with rc 440 injectors. and he ran 12.4 all motor with no traction in first or second with some 13'' slicks on. i cant remember the exact size of the slicks. car is roudy as hell. </TD></TR></TABLE>
damm a 2.1 Liter is HUGE for a B series
Old Nov 11, 2003 | 09:01 PM
0554's Avatar
Default Re: (wicked B16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wicked B16 &raquo;</TD></TR><TR><TD CLASS="quote">
damm a 2.1 Liter is HUGE for a B series</TD></TR></TABLE>
yes the car is insane. i didnt see how it wouldnt get traction with those slicks. i donno its crazy as hell. i got pics of the car if you wanna see. just e-mail me at wrecklessmtrsprt.com but yea the car is rowdy i belive they are shifting at 9500
Old Nov 11, 2003 | 09:04 PM
badasssi's Avatar
fill the back up with bricks and run a 1/4 mile down hill
Old Nov 12, 2003 | 12:39 AM
SoulSurfer's Avatar
Default Re: (badasssi)
Honestly, it doesn't take much more than a good turbo setup with great fuel management.
Spectrum24x
Sep 26, 2005 11:26 PM
waddles08
26
Jul 5, 2005 05:36 PM
91_CRX_Si
Jun 9, 2005 07:44 PM
Spooled1.6L
24
Jan 12, 2004 08:22 AM
