Went to the Track... this engine/gearbox won't die...
Old Nov 10, 2003 | 08:38 AM
Driven's Avatar
Default Went to the Track... this engine/gearbox won't die...
Yes, another 2.4mi hot lap day...
Yes, the B16A and S1 gearbox are still running.
No, I can't seem to break it.
I was for sure I'd grenade the gearbox earlier this year, after the 3rd gear and 4th gear synchro decided to take a hike...making every shift into 3rd anf 4th a grind at any RPM higher than 3000rpms.
The engine is beginning to finally shoot smoke out the taillpipe. Oil is leaking from the VTEC solenoid gasket to the head. I'm sure the rings are pretty worn.
Yet, it still runs relatively strong. I love this engine.
After 7500+ race miles, from drag racing, autocrossing, and hot laps... the only things i have replaced on the engine (outside of the first initial maintenance job) is:
1. oil
2. oil filter
3. distributor cap & rotor (rotor screw backed out, causing the rotor to spin off the shaft and destroy the cap).
4. Gearbox fluid three weeks ago.
that's it. haven't replaced the timing belt. the spark plugs are still as is when I replaced them when I got the engine (some 8500miles ago). No cam seals were ever installed. The water pump was never replaced (even when i got it). Never replaced an axle (not engine based, but, still).
another fun hot lap day...
Old Nov 10, 2003 | 08:45 AM
SiR Kid's Avatar
New User
Default Re: Went to the Track... this engine/gearbox won't die... (Driven)
Tried GM Synchromesh int he tranny yet? It might jsut clean up the 2-3 and 3-4 shifts for yah.
Nice to hear more reliability stories of the JDM engine/trannies... I know you beat your to death! I've seen/heard the videos!
Old Nov 10, 2003 | 10:05 AM
Driven's Avatar
Default Re: Went to the Track... this engine/gearbox won't die... (SiR Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Tried GM Synchromesh int he tranny yet? It might jsut clean up the 2-3 and 3-4 shifts for yah. </TD></TR></TABLE>
I've read little bits and pieces of this, but, haven't dug too deep yet. I should probably research this huh...
Old Nov 10, 2003 | 10:36 AM
roadawg's Avatar
Just curious, are you trying to break the car or something....
Old Nov 10, 2003 | 12:47 PM
Evil EG's Avatar
Default Re: Went to the Track... this engine/gearbox won't die... (hybrid honda)
redline 5th gear and drop to second gear then it will blow.
Old Nov 10, 2003 | 12:55 PM
Escabar's Avatar
dont think the synchros would allow that....
zemerin
May 15, 2014 08:19 PM
wolf95
Oct 27, 2009 01:08 PM
phantom_bcw84
Oct 24, 2006 12:32 PM
Driven
Jun 24, 2002 11:36 AM
