Blown a fuse or something need help!
Auto Windows & door locks are not working only sun roof, any idea's on what this could be? Im thinking a fuse but where is this located on 98 GSR??? I do not have manual, havent bought this yet... Help please....
sound like it....look at ur three pedals gas, brake ect..... under there to the left ...on the side there is a little plastic *** ( it says fuses on the plasic ..thats where you will find the ***)..turn it to the right and pull GENTLY. you will be able to pull the face plate off of the compartment...turn it around...find the fuse for your problem ...(all the fuses and where they go are labed) MAKE SURE YOUR CAR IS OFF! pull out the fuse out ( MAKE SURE TO BUY FUSES BEFORE YOU DO ANY OF THIS!) the fuse should be burned or blown ...REPLACE THIS FUSE W/ THE SAME AMP FUSE..... your problem should be resolved..
GreenD16Y8
Aug 8, 2005 03:59 PM
