Need Advice: I can't make a decision on what cams to get.....
Old Sep 9, 2001 | 03:22 PM
HXMan's Avatar
Default Need Advice: I can't make a decision on what cams to get.....
i am planning on all motor.
i will soon be getting a JDM ITR 4-1 header, cam gears, FPR, and icebox intake, larger TB, new valve springs, and Ti retainers..
I can't decide what cams to get!? I don't do any roadracing....my options probably are Crower 63402's, Jun Stage 2, or Toda spec b's. Stoplight racing, and drag strip racing is about all I do...but I would like a stronger midrange, and much stronger top end. Plus, making power to 9k will be real nice. I like it very much that the crower cams are cheaper, but I am not sure to what power I will get from them.
I can in the future get higher compression pistons, but for now I may just get a mugen head gasket and raise my comp .2 points.
My hondata stage 3 ECU should arrive tuesday(it had better). VTEC adjustment won't be a problem(I really wish there was a hondata tuner in my area)I will get my car dyno tuned, so I will be looking into a VAFC also.
Question is, now that I got the stage 3 hondata, can I upgrade it to stage 4 with the laptop option later? That would rock. Then I wouldn't need the VAFC.....VAFC goes for about 450...maybe uprading to stage 4 would cost about that much.
Oh, and has anyone here replaced their valve springs? Did you have to remove the head? I am thinking it may just be easier to remove the head, and do all the disassembly and reassembly with the head off.
[Modified by HXMan, 6:23 PM 9/9/2001]
Old Sep 9, 2001 | 03:57 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: Need Advice: I can't make a decision on what cams to get..... (HXMan)
Have to Say the Toda B's .. Plus your going to have the Hondata stage 3 so you'll be able to make the mid and topend Phat
Old Sep 9, 2001 | 08:15 PM
earl's Avatar
Whatever cam you pick, be sure to do the valve springs and retainers at the same time. Springs can be installed while the head is on the car but you need the right tools and experience. Some springs need a special cut to be done to the head, so maybe you should pull the head and have a good 3 angle valve job done.
Earl
Old Sep 10, 2001 | 08:20 AM
ANACC2NV's Avatar
New User
Default Re: Need Advice: I can't make a decision on what cams to get..... (earl)
why not get the Crower 63423 if your only going to be doing street racing...
or go with these
TODA RACING VTEC Killer Camshafts
RACING USE ONLY! Makes power from 5000rpm+
Available for: B16A/B, B17A, B18C
TODA VTEC KILLER camshafts are similar to what professional touring car teams have used for years in the British BTCC and Japanese JTCC and Group A racing series. TODA has been offering these camshafts to Japanese race teams for years, and now we are making this advanced technology available to consumers. They are designed for racing only and provide power gains from 5000rpm and up. The camshafts are produced from a special hollow core developed exclusively by TODA Racing for lighter weight and higher rpm capability*. The kit comes complete with camshafts and special hardware needed to complete the conversion. Three different intake and three different exhaust profiles are offered. Special order item! Price: $1,800 Type Duration Lift (mm)
INTAKE 285 12.0
INTAKE 295 12.0
INTAKE 305 12.0
EXHAUST 285 11.5
EXHAUST 295 11.5
EXHAUST 305 11.5
Old Sep 10, 2001 | 08:35 AM
3.3.3's Avatar
Default Re: Need Advice: I can't make a decision on what cams to get..... (ANACC2NV)
jun stage 2....not too wild of a profile. ti retainers & springs are a must.
Old Sep 10, 2001 | 09:13 AM
spyder's Avatar
New User
Yes if you get the Stage 3, you can add the Datalogging and Programming options later. With that, you will be able to change your maps, but you will have to turn the car off to do so. If you use the RaceLogic EPROM Real-time emulator, you can make the changes on the fly with the car running.
If you have any questions about Hondata stuff, go ahead and email them, they are very helpful and very prompt about replying.
Hope your research goes well!
Old Sep 10, 2001 | 02:55 PM
HXMan's Avatar
Default Re: Need Advice: I can't make a decision on what cams to get..... (spyder)
That is what I want, real time data programming. I could optimize my car quickly that way on a dyno.
Thanks about the info guys. I will probably remove the head to do the cams....while I do it I should get some of those flat faced valves too...to raise the compression a little bit.
Does anyone have any experience with aftermarket cams? Like toda, JUN, crower????
Old Sep 10, 2001 | 03:24 PM
alexboy's Avatar
i am in the same situation i have heard great reviews about the juns and toda's but cant decide which set to get peeps have told me todas have be top end but require a higher x over and the juns a great too with a lower vtec x over but make slightly less power than the toda b's
Old Sep 10, 2001 | 03:47 PM
HXMan's Avatar
Default Re: Need Advice: I can't make a decision on what cams to get..... (alexboy)
You might want to look here then.
http://www.importreview.com/performance.html
I guess JUN stage 3 cams have great highend, but are below CTR and Toda cams in the midrange. The jun, and for that fact toda cams both need very well breathing motors. The Jun stage 3's don't make killer power until high rpms, and the toda make good high end too(just not as much). I would have to say the Toda spec b's are looking like the best option. Not the strongest highend, but I would have to say they are great for the street. Reving past 9000 all the time would be really cool with the Jun's, but not all that economical. Toda Spec b's seem to be the best for the street...good midrange, and good highend. Plus, extreme RPMS not required to go fast. I hear the higher VTEC recommendation is around 6200 rpms...but who cars, cuz the non-vtec lobes make great power as well!
b18c eJ1
Mar 24, 2007 01:49 PM
ludespeed501
May 24, 2006 01:05 PM
snowblind7x
Feb 20, 2006 02:34 PM
VtecDA9
Jan 7, 2004 08:12 AM
jaydmcrx
Jan 2, 2004 10:41 PM
