Removing 4th gen Cluster
Old Nov 9, 2003 | 09:19 PM
HKSpowers's Avatar
Default Removing 4th gen Cluster
Can anyone tell me or direct me to a site which explains how to remove to gauge cluster and dash board, for a 4th Gen lude??
Thanks!
Old Nov 9, 2003 | 10:04 PM
caLiH22A's Avatar
Default Re: Removing 4th gen Cluster (HKSpowers)
i don't know if this is much help but this website shows you how to install the jdm climate control, i believe it also shows how to remove the dash, check it out.
http://www.jrcormier.com/prelu...l.php
Old Nov 9, 2003 | 10:09 PM
HKSpowers's Avatar
Well gives me a start, thanks
Old Nov 9, 2003 | 11:07 PM
Taikonaut's Avatar
Not sure how soon you need it by - but my gauge cluster died on me so I'm gonna be replacing that and the little grey box for it too. Not sure when it's gonna get here, but when it does I'll do a photo write up for it
Old Nov 10, 2003 | 02:12 AM
TraKtioN's Avatar
Default Re: Removing 4th gen Cluster (Taikonaut)
I've done this many times for various reasons.
1. Take off the dash speaker grills just pull them off
2. The black roof panel above the cluster has screws in the holes cant miss it.
3. Pull the plastic bottom trim piece off start at one side and pull you wont break anything it just pushes on.
4. remove the screw holding on the plastic divider piece between the cluster and the fuel gauge cluster.
5. remove the screws holding the cluster in, one on each side.
6. remove cluster
Old Nov 10, 2003 | 05:24 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taikonaut &raquo;</TD></TR><TR><TD CLASS="quote">Not sure how soon you need it by - but my gauge cluster died on me so I'm gonna be replacing that and the little grey box for it too. Not sure when it's gonna get here, but when it does I'll do a photo write up for it</TD></TR></TABLE>
there's already one write up on here in the archives
redsidriver
Feb 13, 2007 11:42 AM
wernhersey
Oct 17, 2006 04:47 PM
m1ndless
Oct 8, 2006 07:08 PM
SnkyPY
Dec 27, 2003 10:53 AM
bgod
Dec 17, 2002 12:12 PM
