04RSX Grinding 3rd
Old Nov 9, 2003 | 07:35 PM
jonezey00's Avatar
Default 04RSX Grinding 3rd
ok, so finally bought my dream car... 04 RSX S... driving it home, I noticed some difficulty in the 2-3 shift at moderate RPM. I figured it was just from being used to my 91 integra... It's now been almost 1000 miles and now I"m sure it's messed up. Anyone heard anything about this?
Jones
Old Nov 9, 2003 | 08:17 PM
gsrapper's Avatar
New User
In the s the 1st to 2nd shift has caused problems 2nd to 3rd as far as i know hasn't been a problem. On my s the 2nd to 3rd shift is silky smooth maybe your not use to it
Old Nov 9, 2003 | 08:21 PM
jonezey00's Avatar
Default Re: (gsrapper)
I've driven my friends 2k2 S, and his is also silky smooth. I may have just gotton a bad one from the factory...
we shall see, I'll keep you all informed
Old Nov 9, 2003 | 08:50 PM
dc5 jared's Avatar
i have a 02 rsx-s....and my 2nd to 3rd gear is tempermental as well.....i hear everyone else say 2nd gear grinds....but my second gear doesnt grind at all.....but i am an rsx owner who does have the 3rd gear problem...
Old Nov 9, 2003 | 09:02 PM
duckywucky's Avatar
Default Re: (sleeper dc5)
i have an 04 type-s.... sometimes i miss 3rd..... lol..... thats about it
Old Nov 9, 2003 | 09:10 PM
allmtrSI's Avatar
Default Re: 04RSX Grinding 3rd (jonezey00)
i have heard that the type s tranny is known for gears grinding, at least that's what they say in clubrsx.. but most of the peeps just learn to live with it. i have also heard that in the new 04 models acura was suppose to fix the synchro problem with the type s tranny..
Old Nov 9, 2003 | 09:48 PM
G.Money's Avatar
sometimes when i'm driving casually not paying particular attention...I grind third...i just press the clutch all the way down and do it again
I think third just requires alittle more effort thats all
Old Nov 10, 2003 | 03:40 AM
Davanca's Avatar
Default Re: (G.Money)
I felt the same way when i fisrt got mine S. I thought somethign was wrong with third. I have 3025 miles now at about 1000 i realized it was just me. The S like you to push the clutch all the way down to shift gears. If you try to push it down halfway and shift it will grind and make that awful noise. Just try shifting driving normal. I mean if your racing it, your probably not going to shift very well, because the S is alot different from the B-Series. In the S the gears are right there, they so short and quick. It takes some getting used to. So just drive normal and shift from second to third. Im sure it silky smooth.
Old Nov 10, 2003 | 04:36 AM
that guy steveee's Avatar
Default Re: (davanca24)
dadadadaaadadadad.......ongoing problem that honda does not want to disclose to the public for fear of a bad reputation....if they would admit their car problems and fix them under warranty like nissan did with there Spec-V last year, maybe we would all start buying more and complaining less
I am beggining to dislike Honda Corporation as a whole, VTEC still rules though hahaha
Old Nov 10, 2003 | 05:16 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G.Money &raquo;</TD></TR><TR><TD CLASS="quote">sometimes when i'm driving casually not paying particular attention...I grind third...i just press the clutch all the way down and do it again
I think third just requires alittle more effort thats all</TD></TR></TABLE>
Whats up with that? So do I. I have a 03 type-s with @8,000 mile son it and I noticed that when I drive casually that sometimes third gear has this two-stage notchy feeling, when I think I am in third and let the clutch out it grinds, then after I depress the clutch again I can feel the nothcyness to it. I think there may be a problem. If I am driving spiritedly there is never a problem. Just casual????
Old Nov 10, 2003 | 08:20 AM
duckywucky's Avatar
Default Re: (GreenBean)
i think the problem is a code-18 (computer term for YOU, the driver)
sometimes i **** up 1st, 2nd or 3rd....
but like this morning, 3rd was smooth all the way to school.
Old Nov 10, 2003 | 01:28 PM
t o m's Avatar
Default Re: (duckywucky)
the notchyness is an on and off thing for me. only happens occasionally
Old Nov 10, 2003 | 02:15 PM
jonezey00's Avatar
Default Re: (INTEGRA TYPE S)
I also feel the notchyness, but only in 3rd... today I was hard on it for the first time. I flat shifted 2nd 3rd and 4th 3 times and never had a problem. Then later on I was casually driving and the 2-3 at about 3500 rpm felt like it was in, then grinded like hell when I let out the clutch. we'll see what the dealer says on wednesday morning.
Old Nov 12, 2003 | 05:46 PM
massivespeed's Avatar
There really is a problem with the trans would people please tell me if they have a coldair intake attached or not...... the DC cold will sometimes moved and rub the shift linkage weight. if you have a short shifter and this problem is also occuring trust me honda corp WILL find a way to weazel out of it.
Old Nov 12, 2003 | 09:37 PM
KA-9's Avatar
i am also a 2004 milano red rsx s owner and have that problem. from 1st to 2nd its fine but using the same strength (which is not that hard) going in to 3rd it feels like its in. But its not and the ***** grinds!! I have to sometimes bring it to neutral and jam that stick into 3rd to be sure .. anywhoo i told american honda and all they did was make a appointment for me at my local dealer
Old Nov 13, 2003 | 06:43 AM
GreenBean's Avatar
Default Re: 04RSX Grinding 3rd (Da808FuChan)
Please keep me informed on this, I work for a dealer and my 03-does that exact same thing, I really want to know what they are going to do, hopefully they will take the tranny out and split it open and inspect it...
Old Nov 13, 2003 | 06:44 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duckywucky &raquo;</TD></TR><TR><TD CLASS="quote">i think the problem is a code-18 (computer term for YOU, the driver)
but like this morning, 3rd was smooth all the way to school.</TD></TR></TABLE>
Sorry pal I'm a ways away from 18, but thanks though....
Old Nov 13, 2003 | 06:52 AM
duckywucky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenBean &raquo;</TD></TR><TR><TD CLASS="quote">
i was out last night... not a single grind
Old Nov 13, 2003 | 07:12 AM
DC5 03's Avatar
I have an 03 w/ a March build date, so far no problems with the transmission. If anything it has been getting smoother. Guess it is hit or miss. My buddy's 02 S has already had his transmission replaced w/ the TSB, still not as smooth as mine. Guess I lucked out.
Old Nov 14, 2003 | 06:25 AM
jonezey00's Avatar
Called the dealer yesterday morning, told them everything, they of course want to see it themselves, but they said most likely I'll be getting a new trans.
on a side note, for everyone with crazy high insurance rates, I raised my deductable to 1000 and it dropped it 1500 a year. that's fantastic
Old Nov 14, 2003 | 08:27 AM
t o m's Avatar
cool my deductable is 500 bucks and i pay 1300 a year (under my dads name that is, but i pay for everything)
Old Nov 17, 2003 | 12:09 AM
goofydc5's Avatar
my 3rd sometimes pop out
Old Nov 17, 2003 | 01:33 AM
The HamsterBall's Avatar
maybe try out GM Syncromesh MTF ??
i hear a lot of GSR owners use that to help their grinding..
Old Nov 17, 2003 | 08:06 AM
RockstarJR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonezey00 &raquo;</TD></TR><TR><TD CLASS="quote">ok, so finally bought my dream car... 04 RSX S...</TD></TR></TABLE>
high aspirations eh?
nah seriously... that is b/s I would take it back to acura and make them fix it.
Old Nov 17, 2003 | 08:42 AM
sinical-ep3's Avatar
Default Re: 04RSX Grinding 3rd (ITRChris)
Even though I don't drive an RSX, my car is similar. I used to get second gear grind (and on the occasion I'd grind third). I just changed the way I shifted (holding the shifter from the top like a ball now instead of holding it like a bar) and that pretty much fixed my errors. I get notchiness when its cold though.
eMpAtHy
Jan 22, 2009 10:42 AM
4everVtec
68
Jul 22, 2007 04:11 PM
meblahu
Dec 1, 2006 05:39 PM
b00stn
Oct 25, 2002 02:22 PM
2qwik2nv
Apr 11, 2002 02:56 PM
