Removing pinstripe/sticker???
I have a 99 civic si and I was wanting to remove the pinstripe and DOHC VTEC sticker. What is the easiest way to remove the two?
thanks
thanks
Ladies and gentlemen we are floating in space...
The pinstripe you can just take off with your hands. Just heat it as you go with a hair dryer, it's just a little adhesive holding it on. Then get the crap it leaves behind off with some soap and water or something. I've heard using Goo Gone works for that, but I just used soap and water.
Takes a half hour, max.
I never heard of people putting on the Pinstripe after the first coat paint job then give it a clear coat.
What is best, is to do it in the summer time.
The car is nice and heated. Instead of using a blow Dryer. The sticker film gets really soft, and will be easier to remove. Just comes right off... After then, wipe it down with...uMm ( some Goo stuff?) Forgot whats it called. -=P
i did mine painfully by hand on a cold day..basically just scratch away at it softly and then you should be able to grab enough of it to peel it off...after that i used GOO-GONE on a rag and wiped down the area...
Pinstripes suck!
Pinstripes suck!
well, i removed my pinstripes the other day at work (out of boredome) and on the passenger side, the pinstripes left like a lip or something and u can see that there was something there. it really bugs the hell outta me. im gonan try and buff it today at work and see what that does. how bout taking off the Civic and EX badges on the back? those just pull off and take the glue off with some target?
im pretty sure that the civic and the EX are not bolted on, you could prolly get a string and rub it on the back side of the emblems and '' cut'' them off. but you also might want a 2nd opinion
finished taking off my pinstripes today. it was easier when it was warm. (go figure huh) and i uses a little razor from autozone and VERY CAREFULLY ran it under the striping. easy as 123
donut.
Aug 27, 2005 11:41 AM
What about the sticker? Just do it the same way?
