1990-93 Honda Accord H23 Swap Questions
Old Nov 9, 2003 | 05:33 PM
Red 01 Type-s's Avatar
Default 1990-93 Honda Accord H23 Swap Questions
I would like to have some suggestions on possible upgrades to the Motor itself, in addition are there any wiring problems that are associated with this swap that I should know about beforehand, including upgrades from Auto to Manual... Your prompt responses will be greatly appreciated, as I have a friend working on this swap as we speak...
Thanks 01 Red Type-s
Old Nov 10, 2003 | 07:15 AM
v4lu3s's Avatar
RTFM
wiring is seasy for this swap, on my lx i hada to relocate the o2 sensor, and put new plug on for the EGR and oil pressure switch, then i added the vtec, knock and IAB wiring. it took about an hour with the test fitting included.
auto to manual i had to jumper 2 plugs at teh shifter to get the last one running.
engine upgrades are the same as any other engine...ig you can do it to b series you can do it to H series.
jaimysessanna
Jan 14, 2019 06:57 AM
Pullig
Mar 23, 2010 12:05 PM
Sleeper91
Apr 18, 2008 05:14 PM
-Whitey-
Aug 6, 2006 10:12 AM
