Planning to boost 9lbs on my turbo kit will i need a new map sensor?
Old Nov 9, 2003 | 04:28 PM
BolivianFuego's Avatar
Default Planning to boost 9lbs on my turbo kit will i need a new map sensor?
Will my stock map sensor hold up? Or boosting at 9lbs is it gonna read all that boost?
Old Nov 9, 2003 | 04:35 PM
SKDRCR's Avatar
Default Re: Planning to boost 9lbs on my turbo kit will i need a new map sensor? (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Will my stock map sensor hold up? Or boosting at 9lbs is it gonna read all that boost? </TD></TR></TABLE>
i would get a missing link
Old Nov 9, 2003 | 04:58 PM
Cottonwoodz's Avatar
Hondata says "The stock Honda MAP sensor can see 11 lbs boost."
Old Nov 9, 2003 | 05:04 PM
Default Re: (Cottonwoodz)
hmm.... interesting. How much is a missing link just to know..
Old Nov 9, 2003 | 05:08 PM
sharkcohen's Avatar
Default Re: Planning to boost 9lbs on my turbo kit will i need a new map sensor? (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
i would get a missing link </TD></TR></TABLE>
Whether or not you want/need a missing link depends on your planned engine management setup. What are your plans???
Old Nov 9, 2003 | 05:34 PM
Default Re: Planning to boost 9lbs on my turbo kit will i need a new map sensor? (sharkcohen)
Hondata all the way baby.
Old Nov 9, 2003 | 06:49 PM
blackssvtex's Avatar
i had a missing link on my turbo 97 and they are like 40 to 60
Old Nov 9, 2003 | 06:54 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">Hondata all the way baby. </TD></TR></TABLE>
Then you do not want/need a missing link.
Old Nov 9, 2003 | 07:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
Then you do not want/need a missing link.</TD></TR></TABLE>
Why is this?
Old Nov 9, 2003 | 07:31 PM
GirlNALude's Avatar
i'm boosting 9. not using a map sensor. doing perfectly fine on hondata s200.
Old Nov 9, 2003 | 08:57 PM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GirlNALude &raquo;</TD></TR><TR><TD CLASS="quote">i'm boosting 9. not using a map sensor. doing perfectly fine on hondata s200.</TD></TR></TABLE>
you have to have a map sensor to read boost, but not a 3 bar.
Why is this? </TD></TR></TABLE>
a missing link bleads off the boost so your map sensor doesnt see it. these work great so your ecu doesnt go limp. but w/hondata it reads the boost, not freak out from it. if you use a missing link it wont think your boosting and not give you enough fuel.
Old Nov 9, 2003 | 09:03 PM
GirlNALude's Avatar
Default Re: Planning to boost 9lbs on my turbo kit will i need a new map sensor? (fastludeh22)
sorry, i meant not using upgraded map sensor, just stock.
Old Nov 9, 2003 | 09:04 PM
Default Re: Planning to boost 9lbs on my turbo kit will i need a new map sensor? (GirlNALude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GirlNALude &raquo;</TD></TR><TR><TD CLASS="quote">sorry, i meant not using upgraded map sensor, just stock.</TD></TR></TABLE>
its all good, thats what i figured. just wanted to claifiy for others.
Old Nov 10, 2003 | 08:05 AM
sharkcohen's Avatar
The missing link is a check valve that will prevent the stock MAP sensor from seeing boost. This is useful in applications where the stock ecu must be prevented from sensing boost. In a Hondata setup, the ecu uses the MAP sensor to sense boost.
The fact that you asked something like this means you need a small piece of advice: don't buy a single part until you have a full understanding of what these various components do and how they work.
Old Nov 10, 2003 | 08:21 AM
^haha. Thanks for the advice, but im already into deep. And i think i got it, i just didnt get the whole deal with the map sensor. but good looking out sharkie this is for you.
Old Nov 10, 2003 | 08:40 AM
sharkcohen's Avatar
Old Nov 10, 2003 | 12:20 PM
haha yea im more of a man too. Theres nothing that brings guys togther more then a nice and cold one.
2fastek
Oct 1, 2008 10:38 AM
campyman
Oct 19, 2007 07:08 PM
l2yanE
Oct 2, 2005 10:15 AM
Kidd_Stylez
Nov 2, 2004 04:14 PM
dominate9
Nov 15, 2003 01:01 PM
