wheel and tire size help
Old Nov 9, 2003 | 04:17 PM
itbejack's Avatar
Default wheel and tire size help
I need some help as I do not know a lot about rims and tires...
OK I am going to purchase a set of Work Wheels VS-MX off someone...The size is 18x7.5 the bolt pattern is 5x114.3, came off 99 Eclipse gs-t. Offset is +45
I have a 2003 accord v6 coupe...and his tires are nitto 555.
The problem is two of his tires are 235/40/18 and the other two are 225/40/18...He did this becuase of his turbo...
My question is how should I set up these tires on my car since they are different size...Moreover, which ones should go in the front which ones in rear? I checked a speedo calucator and I will be off by liek 1~2% but how would I calculate since tires are differnt size? Please help
Will this rub agasint my car, it is on stock springs and all...will the 45 offset make wheels stick out a lot? or not at all?
Old Nov 9, 2003 | 04:28 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: wheel and tire size help (itbejack)
the wider tires would go up front since the car is fwd. 235's should still clear the fender, and on stock suspension i dont think you'll have any problems. you could always switch the tires if you do.
Old Nov 10, 2003 | 04:00 PM
.bagged's Avatar
Default Re: wheel and tire size help (fluxion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">the wider tires would go up front since the car is fwd. 235's should still clear the fender, and on stock suspension i dont think you'll have any problems. you could always switch the tires if you do. </TD></TR></TABLE>
makes sense to do it that way but if you are not looking for performance stick the fatties in the rear for cosmetics
Old Nov 10, 2003 | 04:10 PM
qcoffey's Avatar
Default Re: wheel and tire size help (bagged93accord)
I would stick the phatties in the rear. The 225's are probably closer to factory spec anyway. Or just get two new 225's.
addicted2jayz
Jul 3, 2009 10:10 AM
.I.Need.Money.
Jun 14, 2006 06:36 PM
xtremecivichb
May 25, 2006 12:18 PM
tonezilla
Jan 10, 2006 03:48 PM
bluebullet
Jan 5, 2006 11:29 AM
