Welcome Another Rex To Honda-Tech
well, i suppose the first thing your all gonna wanna see is pictures..
DOHC ZC
Port+polished head
Ported Intake Manafold
Bored throttlebody (65mm)
3 angle valve job
Raised Compression ( 12.3:1) [milled head, going all motor zc with this one]
4-2-1 header/Intake/Exhaust
Allinium Flywheel
Summit Fuel Pressure Regulator
Webcams ZC cams reground
Planning on getting suspension next and getting setup for autocross... We all know how well a 2000lb car handles.
Exterior:
Acura Integra rear disc brake conversion
16" Team Dynamics Motorsports with 205/40/16 Kuhmo Supra Ecsta ( expensive tires, dont by... Just get Faulken Anzenis...)
well, post your comments, im on the board everyday so ill keep on touch a lot.
DOHC ZC
Port+polished head
3 angle valve job
Allinium Flywheel
Exterior:
I have stock lights that i can use, but I kinda like the ones I have now. With it lowered it will look much nicer.. lol kidhonda, did you have same name on resources?
Yes I did go by the same on the resource. All auto boards I go by kid-honda. And to comment on the car. I love it...minus the tails, sorry its all cool but the tails. Aside from the tails keep up the good work and props on the NA ZC. Not a common approach.
Hit up the all motor board on here thats what brought me over these guys aint a bunch of 16 second plus cars. Its another world then you are used to were DC headers and HMI's make your car top ****.
You like that last word I used, you dont get banned for that here.
thats wierd.......... never thought id see an old school zc in a ef body... the valve cover bolt locations mean that its either an old olive top zc or a first gen integra dohc motor d16a1 i believe is the engine code......
any hoots motor looks good......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peters1983 »</TD></TR><TR><TD CLASS="quote">nice car , also love the signature. thats some good ****</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote"> i also noticed the valve cover.. seeing as how it is squared, instead of sloping towards the intake, and has the H on the intake side..</TD></TR></TABLE>
also if you noticed the bolts are in the middle near the spark plugs and where the 88 and up dohc zc has the bolts on the outer side ........2 nearest exhaust and 2 near intake manifold.....they first gen zc's only have like 112hp as where the 2nd gen have @130hp
bump, what motor is this? is it an 89 integra head? i've read those can go onto the black top zc blocks with some work. how much is your head milled anyways? 12 something compression? wow. my zc head is milled .022 with a thinner cometic headgasket, and i think it calculated out to be 10.6:1... like that color paint man, sweet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">how much and where at in florida is that? im in central florida</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=675292
I posted them up with more info and pics..
Newbie de-ricing period is usually 1-2 weeks. j/k
