Questions about Possible Setup for my b18c1
Old Nov 9, 2003 | 12:05 PM
GsR HtCh's Avatar
Default Questions about Possible Setup for my b18c1
This is the setup i am probably going to run on my b18c1. Feel free to make any comments you want and to let me know if you would add anything or take anything away or even change something. Im not going to bore it out just yet. I dont have the money right now. My immediate goal is the be in the 13's on street tires and long term is 12's or 11's allmotor on slicks, so right now im looking at gettin into the mid to low 13's. I posted this in the eg forum but figured id get a better response from the NA pros here. Thanks.
-high compression pistons, ITR, JE's or CP's 12.5:1
-P&P stock GSR head
-skunk2 Stage2 cams
-stiffer springs and retainers
-skunk2 intake manifold
-ITR TB
?-bigger injectors 310cc
?-bigger fuel pump 190lph or 255lph
-apex-i VAFC
?-adjustable FPR
-and a good tunner(Hondata)
a few ?s come up.
-injector size. what will be best for the setup.
-fuel pump what size 190 or 255
-do i really need an adjustable FPR or not
-do i need an VAFC if i get hondata.
-do i need inner AND outer springs or just outer ones
there you go. did i forget anything. PEACE.
Old Nov 9, 2003 | 12:41 PM
advanracing62's Avatar
Default Re: Questions about Possible Setup for my b18c1 (GsR HtCh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR HtCh &raquo;</TD></TR><TR><TD CLASS="quote">
-injector size. what will be best for the setup. 310 should suffice
-fuel pump what size 190 or 255 I'd go bigger, and tune it out with hondata
-do i really need an adjustable FPR or not Yes/no.. depends on what you're trying to do over all... It's a good safety tool
-do i need an VAFC if i get hondata. nope
-do i need inner AND outer springs or just outer ones inner and outer, EF-1 comes to mind
tuner has one N
Old Nov 9, 2003 | 01:56 PM
GsR HtCh's Avatar
Default Re: Questions about Possible Setup for my b18c1 (advanracing62)
thanks for answering my ?'s anyone have anything to add
Old Nov 9, 2003 | 05:24 PM
GsR HtCh's Avatar
Old Nov 9, 2003 | 06:13 PM
Professor15's Avatar
wat kinda headers u gonna be running? if u gots the money n time go for a sms header. and i think the ctr pistons will get u closer to 12.5 comperssion.
Old Nov 10, 2003 | 07:14 AM
GsR HtCh's Avatar
Default Re: (drchulo)
im running greddy headers but i plan to upgrade. JE makes pistons that put you at 12.5:1 compression.
Old Nov 10, 2003 | 08:00 PM
GsR HtCh's Avatar
Default Re: (GsR HtCh)
i want to get a smsp header but i heard the wait is long. maybe ill just get a DTR or equivelant
GsR HtCh
Nov 21, 2003 11:46 AM
GsR HtCh
15
Nov 15, 2003 12:46 AM
GsR HtCh
Nov 11, 2003 10:19 AM
GsR HtCh
23
Nov 10, 2003 07:59 PM
GsR HtCh
Nov 10, 2003 01:51 PM
