head gasket Q (kinda searched)
have any of you guys used the OEM gasket minus a layer?
i know they do it alot with VW's so i was just wondering
when i searched i got 755 results and i'm off to work so i figured i'd rely on my boys at HT
From: san diego, miami, rosarito mx, rio de janeiro, guangdong
i have the oem gasket minus two layers
...i think i used the upper one
------ sprayed copper spray on it.. runs fine..
use the outer ones if you goin for two..
------ sprayed copper spray on it.. runs fine..use the outer ones if you goin for two..
stock a2 block, ported head, one layer oem gasket, crower 401s n valvetrain, mugen p28, dc 4-1, itr manifold, stock TB, stock fpr n injectors, UNTUNED..hehe --EF si body, runnin on 14x8x20s with a 1.9 60ft
well i pieced tho motor together so when it was time to put the head on the block, i cut the gasket.......using ARP head studs...........
B18cHatch06
Jan 18, 2006 07:23 PM
