dead coils
Old Nov 9, 2003 | 11:20 AM
b4uagain's Avatar
Default dead coils
my dead coils are rubbing up against each other making a metal clanking noise, is there anyway i can get rid of the noise.
Old Nov 9, 2003 | 09:24 PM
foot's Avatar
Default Re: dead coils (b4uagain)
What is a dead coil?
Old Nov 10, 2003 | 03:55 AM
02-sir's Avatar
My Prokits came covered with plastic tubng where the dead coil stops and the active coil begins (i.e where the coils start to space out). It looks like the soft , clear pvc tubing you can get from home depot. I would give that a try, you only need enough to make one revolution around the spring. If you want it to stay in place, you'll have to remove the spring and push the tube on from the end (i.e. don't split the tube along it's length and stick it on the easy way)
HTH
Old Nov 10, 2003 | 08:16 AM
GreenBean's Avatar
Default Re: dead coils (02-sir)
Have you tried to see if the dealer sells the "spring silencers" themselves. I think that is what you are talking about. They came on my Terin springs and I thought there was a set on your factory springs, but they might get ate up trying to remove them.
Old Nov 10, 2003 | 10:09 AM
CHILIBEANZ's Avatar
https://honda-tech.com/zerothread?id=664870 go to my post it has all u need. now the link works
Modified by p220 at 3:55 PM 11/10/2003
Modified by p220 at 3:56 PM 11/10/2003
Modified by p220 at 3:57 PM 11/10/2003
_Cyclone_
Suspension & Brakes
Apr 13, 2005 12:16 PM
joshalee
Jun 29, 2004 10:20 AM
joshalee
Apr 30, 2004 08:45 PM
tylerdurden
Apr 19, 2003 03:14 PM
sLo B18b
Jul 4, 2001 11:21 PM
