Changing the alternator belt?
Old Nov 9, 2003 | 09:08 AM
Jet Black's Avatar
Default Changing the alternator belt?
The shop manual has a specific method and deflection that should be observed for the belt. Something like 7-9 mm for 22lbs...any idea how to ghetto check this?
Old Nov 9, 2003 | 10:32 AM
blah13's Avatar
Default Re: Changing the alternator belt? (Jet Black)
Once the belt is put on, try and twist the belt. It shouldnt twist more than 90 degrees, or if your looking at the belt from above (belt is flat) when you twist it it should not be able to go past being vertical (up and down). Heh, hope that made sense.
Old Nov 9, 2003 | 10:42 AM
RiceRacist's Avatar
Default Re: Changing the alternator belt? (blah13)
exactly perfect explanation
Old Nov 9, 2003 | 12:11 PM
Jet Black's Avatar
THanks guys.
JasonST
Sep 6, 2013 10:02 AM
patrickstar
Feb 7, 2009 09:04 PM
mohsinkhan35
Sep 2, 2005 06:21 PM
Kato7997
Feb 23, 2003 11:23 AM
