!!!CODE 43!!! FUEL SUPPLY SYSTEM
Old Sep 9, 2001 | 02:55 AM
DelsolVtec18's Avatar
New User
Default !!!CODE 43!!! FUEL SUPPLY SYSTEM
I got a 96 GSR and i am getting a code 43 (Fuel Supply System
defective or malfunctioning fuel supply system) can anyone tell me what could be wrong and how can i fix it.....THANKS!!!
Old Sep 9, 2001 | 09:38 AM
fixhondas's Avatar
Default Re: !!!CODE 43!!! FUEL SUPPLY SYSTEM (DelsolVtec18)
Probably an O2 sensor is dead or dying. Is it still OBD2? Could be a fuel trim problem.
[Modified by fixhondas, 6:38 PM 9/9/2001]
Old Sep 9, 2001 | 10:39 AM
New User
Default Re: !!!CODE 43!!! FUEL SUPPLY SYSTEM (fixhondas)
Nah my car is OBD1...Yeah my friend said that it might be a O2 sensor problem too...so i might just change my O2 sensor first and then see wassup...What kind of fuel trim problem could it be if its not the O2 sensor...like what part should i check...THANKS FOR THE INFO
Old Sep 9, 2001 | 12:28 PM
fixhondas's Avatar
OBD2 monitors fuel trim- OBD1 does not.
Old Sep 10, 2001 | 08:27 AM
VTEC4GS's Avatar
curious if you just finished installing an autometer a/f ratio meter ?
yes its a low signal goign to the ecu from the O2 sensor.
Greg
Old Sep 10, 2001 | 01:19 PM
New User
Default Re: !!!CODE 43!!! FUEL SUPPLY SYSTEM (vtec4gs)
Yeah my autometer air/fuel gauge has been installed for a while already...yeah i am trying to find a new o2 sensor so i can fix my cel.
Old Sep 11, 2001 | 05:31 AM
drift's Avatar
New User
it's not your O2 sensor. the O2 sensor has it's own code. but if you're ready and willing to listen to these halfwits and burn cash on an O2 sensor, you can send the $90 it will cost to me. or you can shop at http://www.oxygensensors.com
check your EGR valve, fuel pressure, and injector wiring. also consider changing out your fuel filter if you havent done it lately. also ensure the fuel pressure regulator and it's vacuum line isn't clogged and is functioning properly.
if all these check out fine, have your injectors inspected. one may be cracked or severly clogged, therefore not able to pulse properly and setting off a check engine light
Old Sep 11, 2001 | 05:59 PM
fixhondas's Avatar
Default Re: !!!CODE 43!!! FUEL SUPPLY SYSTEM (drift)
A code 43 indicates a problem in the O2 sensor heater circuit or the fuel supply system. If the car drives fine then it is most likely the O2 sensor heater or its wiring or it is not creating voltage or it is not switching. There are two causes of this- a bad O2 sensor or inaccurate fuel metering. A fuel supply system problem WILL be accompanied by poor driveability- If you have a graphing voltmeter you can hook it up to the O2 signal wire and watch the voltage output. An O2 sensor that does not switch properly or is dead will yield a code 43- it is not too difficult to test the O2 sensor but then again- what the hell would I know- I only work on Hondas every day. I have yet to see a code 43 set by something other than a bad O2 sensor. A bad heater will set the light soon after you start the car while a bad signal from the O2 will take some driving.
If you do decide to replace the O2 sensor I HIGHLY recommend getting the Honda piece- it is expensive but worth it.
Who exactly is a "Halfwit?" Maybe you should do some research before you open your mouth. By the way- the O2 sensor can signal a code 1, 41, 43, or even a 48.
Old Sep 12, 2001 | 10:38 AM
New User
FIXHONDA IS RIGHT...I DONT THINK YOU SHOULD BE CALLING ANYONE HALFWITS CAUSE I CHANGED MY O2 SENSOR AND NOW MY CAR IS FINE...NO MORE CHECKLIGHT AND AIR/FUEL GAUGE READING IS BACK TO NORMAL...
FIXHONDAS IS THERE ANYWAY TO FIX THE OLD O2 SENSOR....I THINK THERE IS A BAD SIGNAL GOING TO THE O2 SENSOR CAUSE THE CEL COMES ON AFTER I DRIVE FOR A WHILE...
!!!!!!THANKS FOR ALL THE HELP!!!!!!
[Modified by DelsolVtec18, 12:28 AM 9/13/2001]
[Modified by DelsolVtec18, 1:27 AM 9/13/2001]
Old Sep 12, 2001 | 12:12 PM
markaria's Avatar
hey maybe one of you could help me out.. My beater/ go to work car is a 1988 accord lxi (fuel injected) with high miles (205,000). The car throws an O2 code but the cel only comes on if I drive at a steady speed/load for a few minutes. Now the car has been completely tuned up, (I changed the fuel filter, adjusted valves, replaced cap/rotor/wires/plugs, replaced both o2 sensors) but the problem is still occuring. As a side note, before the cel comes on it seems that when I go to accelerate there is a bit of a hesitation, and then it accelerates fully (feels almost like turbo lag). after the cel is on however, the hesitation seems greatly diminished.
any help out there amongst all of you honda gurus?
Old Sep 12, 2001 | 04:06 PM
fixhondas's Avatar
Default Re: !!!CODE 43!!! FUEL SUPPLY SYSTEM (markaria)
No, you can't repair the O2 sensor.
Markaria, it may be possible that your O2 sensors are hooked up backwards. It may also be possible your TW sensor is inaccurate. When the light comes on- your car is running open loop and does not look at O2 voltages.
avrfan
Aug 25, 2014 01:59 AM
Achenar
Apr 18, 2004 02:06 AM
spencedogg
13
Oct 28, 2003 06:45 PM
Btothe3rdDegree
10
Jun 22, 2003 04:51 PM
