type r into a hatch
In what regards..............you mean accesories like the drive axles and wiring harness..ecu........Let me know what you mean and i can help you. I just put one in my 00 si.
yeah i have a complete type r car that we are in the process of cutting up, im trying to find out what else besides what i have i will need to put in to a 92 vx hatch, i have nothing but what came with the type r
you dont need anything besides a chipped p28 ecu.
the dc2-r wiring harness is plug and play since you car is a 92 and pre-wired for vtec. use all dc2-r engine mounts and brackets. use dc2-r throttle cable, axels, and shift linkage. you will probibly need to reuse the civic clutch soft line.
replace your fuel filter with a stock civic one. you may want to upgrade your radiator to at least a del-sol dual core, and you may need a custom cat depending on what header you use.
have fun, your car will be faster than most "sports" cars.
btw: get nice tires.
