Does anybody know if a 17"-8", 45mm offset will fit an RSX without problems???
I was wondering b/c the offset is the same but the extra width would be on the outside right? The new TL has some sweet wheels, not light though. But they are a 17"-8"...Tirerack said it probably would. Does anydoby here have such wheels of this size on their RSX. Thanks in advance
By my figuring you'll be wider on the outside by .75". You should measure your current clearance to be sure. Sounds like it will fit, King Motorsports runs 17x8 on their RSX, I think the offset is 50mm though.
http://toy4two.home.mindspring.com/offset.html Check it out, snap out yer tape measure and this will do the rest.
donetoperfection
Jan 27, 2008 02:22 AM
dubnobass
Aug 23, 2006 12:06 PM
