whats up with this?
well i just put 90 teg knuckles on my car ...and i went to drive it, (drove normal no crazy braking), the car felt kinda sluggish, i went 5 miles and got home and the rotors are red....wtf? do i need the brake master clyinder off a teg? the booster? or are the brakes assembled wrong.
any help would be greatly appreciated ASAP. thank you.
Woah
Your calipers are seized on...whats causing that ...I donno.
I assume you grabbed the teg calipers and such when you put the knuckles on?
You could try pulling the wheel, detaching the caliper (will prolly be hard as hell since its seized on. Compress the piston with a clamp (loose the brake fluid resevoir cap) You should then lubricate your sliders with the appropriate grease (I dont know what its called...someone help me here)
Pierre
Pierre
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 »</TD></TR><TR><TD CLASS="quote">its not called anything fancy its just called caliper grease</TD></TR></TABLE>
thank you smartie....wanna tell me how i can put it on .and what not
FourthGenHatch
46
Jul 27, 2003 07:07 PM
