Rear H embem on the EP3
Old Nov 8, 2003 | 02:28 PM
Ep3-4-EVA's Avatar
Default Rear H embem on the EP3
Does anyone know how to take off the stock H emblem off the back of the EP3? I bought the red type r one but i cant get that lil **** off.
Old Nov 8, 2003 | 03:49 PM
GreenBean's Avatar
Default Re: Rear H embem on the EP3 (Ep3-4-EVA)
The way we take them off at the shop is with a piece of string that you can wrap around each hand. Get an edge started and then just easily run it back and forth under the emblem. There will be two side by side "tabs" that center and level the emblem. The new one should have the plastic "rubbers" over each one. Then throughly clean all the old adhesive off. It make take a while. Then press and stick....
Then after the adhesive dries for a couple of minutes you can SCRATCH and SNIFF
Old Nov 8, 2003 | 04:56 PM
Todd00's Avatar
I said I don't want a title!
Default Re: Rear H embem on the EP3 (GreenBean)
Yeah, I used fishing line to get mine off.
Old Nov 8, 2003 | 06:08 PM
glw's Avatar
glw
Default Re: Rear H embem on the EP3 (Todd00)
dental floss
Old Nov 8, 2003 | 09:23 PM
civicvtec1ps's Avatar
I used my finger to get it off. and cleaned with wd 40. worked perfectly fine.
Old Nov 10, 2003 | 06:07 AM
that guy steveee's Avatar
Default Re: Rear H embem on the EP3 (civicvtec1ps)
I used a SMALL screwdriver and some thin cloth over the metel. but first i heated the adhesive with a blowdryer first so it wouldnt be so hard to peel off.
Old Nov 10, 2003 | 01:14 PM
tornactive.com's Avatar
Default Re: Rear H embem on the EP3 (simann)
2lb fishing line.
Real thin and can easliy pull it off with out risk of scraping the paint.
chillerice
Feb 10, 2013 06:20 AM
kikoman0
Jan 5, 2005 03:26 PM
im_the_teacher
Mar 4, 2004 09:03 PM
evilash
Mar 19, 2003 04:12 PM
cyan1de
Jan 8, 2002 11:06 PM
