Overfilled my oil, cause for concern?
Old Nov 8, 2003 | 12:25 PM
RGoose18's Avatar
Default Overfilled my oil, cause for concern?
Just checked my oil cold, very high. After a brief warm up, I let it cool down for about 5-10 minutes, still slightly high, should I drain some, or is this something I shouldn't worry about? Any suggestions are appreciated
Old Nov 8, 2003 | 12:27 PM
Dirt's Avatar
Default Re: Overfilled my oil, cause for concern? (RGoose18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 &raquo;</TD></TR><TR><TD CLASS="quote">should I drain some, or is this something I shouldn't worry about? </TD></TR></TABLE>
Yes, and yes. Foaming oil is not good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions are appreciated </TD></TR></TABLE>
Drain and refill with 4 quarts. Done.
Old Nov 8, 2003 | 01:41 PM
Bbasso's Avatar
Default Re: Overfilled my oil, cause for concern? (BrewCityR)
cough cough... 4.5 qts?
Old Nov 8, 2003 | 02:08 PM
Dr Pooface's Avatar
Default Re: Overfilled my oil, cause for concern? (Bbasso)
I wouldn't worry about the oil being "slightly high".
Old Nov 8, 2003 | 02:37 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Overfilled my oil, cause for concern? (Dr Pooface)
If it's over by less than half a quart, don't worry about it.
If it's over by more than a quart, drain it.
In between, toss-up, your choice.
Old Nov 8, 2003 | 03:58 PM
markpaco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">cough cough... 4.5 qts?</TD></TR></TABLE>
4.5 with filter, 4.0 w/o filter.
Old Nov 8, 2003 | 04:15 PM
RGoose18's Avatar
Default Re: Overfilled my oil, cause for concern? (markpaco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">
4.5 with filter, 4.0 w/o filter.</TD></TR></TABLE>
The stock honda oil filters don't hold 1/2 quart, do they? Honda recommends 4.2 quarts, I figure thats 4 quarts and the oil filter.................I added some oil about a week ago because I was burning quite a bit, although I guess I added too much. I'm gonna loosen the drain bolt just a hair and try to level it out, instead of draining it all and redoing the entire process. It wouldn't be a big deal to do it all again if it weren't 10 degrees out. NH winters =
Old Nov 8, 2003 | 04:57 PM
Ferrell's Avatar
Just burn it off.... thats what I do
Old Nov 8, 2003 | 06:45 PM
vtec.dc2's Avatar
how high? few mm? if so.. it should be fine - i never had problems because of that.
Old Nov 9, 2003 | 08:18 AM
onyx00's Avatar
Default Re: Overfilled my oil, cause for concern? (vtec.dc2)
Yeah, I overfill when I use Mobil1 just because I burn it and want to have extra in there.
I wouldn't worry too much. Follow rules nsxtasy gave.
Old Nov 9, 2003 | 08:25 AM
P1mpSlap's Avatar
Default Re: Overfilled my oil, cause for concern? (Ferrell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ferrell &raquo;</TD></TR><TR><TD CLASS="quote">Just burn it off.... thats what I do </TD></TR></TABLE>
ROFL
sadly I do the same thing. Sucks having a fucked up piston ring.
Old Nov 9, 2003 | 12:03 PM
RGoose18's Avatar
Default Re: Overfilled my oil, cause for concern? (P1mpSlap)
How can I tell if I fucked something up within the engine. I drove it about 30 miles w/ it overfilled, then I drained it and changed it. I took it for a drive today and it seemed sluggish, think it's related??
Old Nov 9, 2003 | 02:59 PM
SleepnCiViC's Avatar
all in your head
Old Nov 9, 2003 | 03:18 PM
dk127's Avatar
I agree all in your head... But how much did you over fill it?
Old Nov 9, 2003 | 04:30 PM
whtdc2's Avatar
New User
Default Re: (dk127)
so can you guys please tell me when should I check the oil level?? When it is cold in the morning, or when the engin is warm or hot?? Thanks
Old Nov 9, 2003 | 06:03 PM
RGoose18's Avatar
Default Re: (whtdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whtdc2 &raquo;</TD></TR><TR><TD CLASS="quote">so can you guys please tell me when should I check the oil level?? When it is cold in the morning, or when the engin is warm or hot?? Thanks</TD></TR></TABLE>
Yeah, I need an answer to this too. Also, I filled it pretty close to a quart over, pretty much a dumbass move, but it was over the course of a couple weeks, thought it was burning, guess it wasn't
Old Nov 9, 2003 | 06:06 PM
baonest1's Avatar
Default Re: (RGoose18)
you can check the oil anytime.. cold or hot. if its cold then that is pretty much where the oil is because it is all drained to the pan. if the car has been ran, then you check it, you need to compensate for some oil in the head so its roughly 1/2 quart off.
someone elaborate on the COLD vs HOT deal. i just figured cold meant its all settled in the pan, and hot meaning you just turned the car off.
but too much oil can do damage. at least for v-8s i know it can, it basically does the same thing water does, hydrolock, but its called somthing else i think. just be carefull and if its too high, drain some out. and sell it back
Old Nov 9, 2003 | 06:07 PM
uncleben's Avatar
i always figured after it'd been running for a bit. the manual says to fill the oil, then let it run for a few minutes, re-check, then add as necessary. right?
Old Nov 9, 2003 | 07:47 PM
RGoose18's Avatar
Default Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC &raquo;</TD></TR><TR><TD CLASS="quote">all in your head</TD></TR></TABLE>
I'm not sure about that, would it be quite obvious as to whether something was damaged or would you have to open it up and inspect the rings?? As I said before, I over did it by about a quart.
Old Nov 10, 2003 | 02:33 AM
epy's Avatar
epy
Default Re: (uncleben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncleben &raquo;</TD></TR><TR><TD CLASS="quote">
i always figured after it'd been running for a bit. the manual says to fill the oil, then let it run for a few minutes, re-check, then add as necessary. right?</TD></TR></TABLE>
pretty sure they tell you to run it so you can see if any is leaking/dripping. I remember the manual saying if so then reinspect your work.
I say just drain a little like you said you did. It shouldn't be a problem I mean you should have it resolved in less than an hr.
crazyguy
Sep 27, 2007 04:38 PM
John 07
Feb 3, 2007 06:58 AM
invisible
21
Dec 27, 2006 08:27 AM
97dc2
Aug 3, 2005 09:39 PM
Y2A
Nov 17, 2004 05:31 AM
