H22 in Teg...how to keep a/c+pwr steering?
Old Nov 8, 2003 | 03:21 AM
its WANG yoO's Avatar
Default H22 in Teg...how to keep a/c+pwr steering?
i'm gonna be doing H22 swap soon in my 00 integra..how do i keep the a/c and power steering?
also...do you guys think its wrong to put a 92-96 H22 in a 00' integra? i can't seem to find a JDM motor any newer then that...
Old Nov 8, 2003 | 08:37 AM
Newman's Avatar
New User
Default Re: H22 in Teg...how to keep a/c+pwr steering? (inJDMtegra)
Just replied to your other post where you asked that question, but here it is copied & pasted.......
Easiest way in an Integra.... refit a Civic SOHC compressor to the Integra lines and use the HCP AC bracket and bolt it right up. If you try to use the Integra compressor or Prelude compressor, it's going to hit the radiator. On the DC/EK chassis, you can use the 92-96 PS pump and bracket as they'll clear the hood. On the EG chassis, you need to use the smaller 97+ Prelude PS pump & bracket. It's been done quite a few times already so no real problems there..... just weld those high pressure lines so you don't run into any problems down the road.
Old Nov 8, 2003 | 12:16 PM
90crxb16a's Avatar
or get one of the half radiators and keep your stock equip.
Old Nov 8, 2003 | 12:31 PM
Default Re: (90crxb16a)
ok..so i can use a 99 Ex A/C pump? and just make the lines from the teg fit?
also..for the power steering...can i use my stock Integra P/S line on the prelude pump?
newman...how much is the a/c bracket...
also...my friend has been trying to get ahold of you for a few days to order Vision Ecu and jumper harness...and i want a set of teg/H22 mounts!
Keeper1343
Sep 16, 2007 10:26 AM
skinnyboy
May 4, 2006 12:19 AM
Accord4Sure
Aug 19, 2005 09:41 AM
CrVtec122
Jul 7, 2004 07:49 AM
nickdoe
Nov 24, 2003 05:40 PM
