coilover installation on 90 SI
Old Nov 8, 2003 | 01:09 AM
shittyDAndy's Avatar
Default coilover installation on 90 SI
could a average guy with pretty decent capablity to work on cars put them on. i just bought GC with tokikos and they are already put together but if anybody has time could they help me out and give me some detailed directions. my buddy can put them on but id have to wait till wends help me out!
Old Nov 8, 2003 | 02:14 AM
SiR Kid's Avatar
New User
Default Re: coilover installation on 90 SI (shittyDAndy)
Super easy in the back. Two nuts in the interior at the top, one bolt at the lower control arm.
Front, you have to take a ball joint loose. Lower is easiest for me. then remove two bolts under the hood for the top of the strut, and then the two bolts to remove and loosen the wishbone.
Easy peasy.
Old Nov 8, 2003 | 06:24 AM
Lo-Buck EF's Avatar
Default Re: coilover installation on 90 SI (SiR Kid)
even easier in yhe front:seperate the shock from the shock fork. then u can snake it out and then unbolt the shock from the tower and remove it from the car. u have to do this anyway because u have to use the shock fork on the new sus.
Old Nov 8, 2003 | 07:20 AM
senpai's Avatar
If you're just swapping, then piece of cake. Just watch for rusted bolts ...
Old Nov 8, 2003 | 07:55 AM
89s1's Avatar
Default Re: coilover installation on 90 SI (maztur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote"> Just watch for rusted bolts ... </TD></TR></TABLE>
lol werd.
I stripped all sorts of stuff taking apart my 89si's suspension the first time after i bought her.
Old Nov 8, 2003 | 10:53 AM
thanks for the help guys im going to give it a try in like 2 hours!
Old Nov 8, 2003 | 11:16 AM
X-Static's Avatar
i did all 4 in 12 hours my first time...but that includes the time it took trying to get my Ingalls ancor bolt camber kits into the UCA's ...oh and an hour lunch break
Old Nov 8, 2003 | 11:21 AM
Ef Whore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid &raquo;</TD></TR><TR><TD CLASS="quote">Super easy in the back. Two nuts in the interior at the top, one bolt at the lower control arm.
Easy peasy.</TD></TR></TABLE>
No need at all to loosen a balljoint....real simple, just remove shock fork LCA bolt, remove shock fork to shock bolt, take out fork, remove the two 14mm bolts under the hood, lower the assembly out. All rod ends/balljoints stay intact. If your bolts aren't rusty, then the car could be fully done in an hour. Oh yeah there are also a few various brakeline bolts on the shock.
Old Nov 8, 2003 | 10:18 PM
thanks for the help guys. i got it done in little over 2 and a half hours. with a little lunch break.....dope!
Old Nov 8, 2003 | 10:45 PM
Quik89Si's Avatar
Good job! So is the ride improved, or what?
Alex
Old Nov 9, 2003 | 01:42 AM
westcoastcat's Avatar
is it easyier to install lowerin springs on a 89 hatch? id like directions and a si/ex tranny..;o)
EGhatch33
Suspension & Brakes
Dec 18, 2005 10:36 AM
Dseriespower
10
Dec 7, 2003 08:09 PM
^Sammy]!.
Sep 22, 2003 05:47 PM
98slvrcx
20
Aug 25, 2002 10:16 AM
