pro's and cons of oversized valves
Old Nov 7, 2003 | 05:12 PM
kwik92hb's Avatar
Default pro's and cons of oversized valves
going to do a rebuild on my d16z6 take the bore to just 20 over wanting to do new valves,is oversized say .5 mm bad,wrong,great should i do dished,flat or what i have the comp 59300 cam also.please educate anyway u can before i purchase
Old Nov 7, 2003 | 07:01 PM
chrisCNL's Avatar
Default Re: pro's and cons of oversized valves (kwik92hb)
i think you should go over size only if you have enough air to flow through the motor ie turbocharge or supercharge.
Old Nov 7, 2003 | 08:17 PM
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik92hb &raquo;</TD></TR><TR><TD CLASS="quote">going to do a rebuild on my d16z6 take the bore to just 20 over wanting to do new valves,is oversized say .5 mm bad,wrong,great should i do dished,flat or what i have the comp 59300 cam also.please educate anyway u can before i purchase </TD></TR></TABLE>
If ya seen what I was doing to The ZEX car HEAD you would ****!!!
Old Nov 7, 2003 | 08:19 PM
Rob Dizzle's Avatar
Default Re: pro's and cons of oversized valves (chrisCNL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisCNL &raquo;</TD></TR><TR><TD CLASS="quote">i think you should go over size only if you have enough air to flow through the motor ie turbocharge or supercharge.</TD></TR></TABLE>
ditto, stock size is fine
Old Nov 8, 2003 | 04:15 AM
kwik92hb's Avatar
i forgot to mention i was useing a nx express kit,single shark nozzle going to convert to direct port
Old Nov 8, 2003 | 04:19 AM
kwik92hb's Avatar
Default Re: pro's and cons of oversized valves (MAX_CFM)
are u talking about the yellow crx?i'll be switching to direct port also if that matters about using a bigger valve or not,i would love to have ur input on this one since u are the man in this choice of topic
Old Nov 8, 2003 | 08:54 AM
earl's Avatar
Dished valves are lighter and drop about .2-1 in your compression ratio if you are switching from a flat head valve.
Flat head valves raise your compression ratio slightly but are slightly heavier.
Since your engine is essentially an air pump, .5mm oversized valves will help it breath better.
BTW, you need upgraded springs and titanium retainers if you have not made that modification yet.
I use the SuperTech springs and valves in my race car and love them.
I can hook you up with a good price on them if you are interested.
Old Nov 8, 2003 | 10:51 AM
HEAD's Avatar
in my opinion if you do not open the bowl in relation to the size of the valve putting a larger valve in the head would be futile.
Old Nov 8, 2003 | 01:17 PM
earl's Avatar
Default Re: pro's and cons of oversized valves (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">in my opinion if you do not open the bowl in relation to the size of the valve putting a larger valve in the head would be futile.</TD></TR></TABLE>Yeah, it certainly isn't a drop in installation
Old Nov 8, 2003 | 01:47 PM
MAX_CFM's Avatar
your right throat size is important with big valves
Now the right size thats the ticket
mikeh74
Nov 15, 2008 03:52 PM
CivicLxFL
Feb 8, 2007 12:37 PM
99CivicSiBrian
May 31, 2006 01:23 PM
gitwidit
Oct 31, 2005 04:00 AM
Serdar
Dec 3, 2004 04:05 AM
