FS: Mallory Hyfire VI CD Ignition (685) and Promaster Coil (650-29440)-For H22
Brand new Never Taken out of Box - Perfect for nitrous setups
-Promaster Coil (650-29440)-For H22 only
-Digital ignition- For any import.
Primary revlimiter (topend)
Secondary rev limiter (triggered by 12v, can be used as a starting line low rpm limiter or whatever you want)
Start retard (easy starts)
Built in 2 stage window switch (perfect for turning your solenoids on at a certain rpm and cutting them before the rev limiter)
Timing retart (triggered by 12v, so you can run regular timing off the bottle)
If you are looking for a new ignition. This is comparable to the MSD Digital 6 Plus ignition, but it has a window switch built in, LCD display for adjustments (no *****) and is hell of alot cheaper then the MSD version. Looking for 290 shipped for coil and ignition. Will seperate if i could get 2 solid buyers for each.
Modified by BolivianFuego at 9:45 PM 11/7/2003
my_slow_civic
Dec 14, 2006 04:41 PM
